MT90 Rear Tube tire on an XJ650 Seca 82
Discussion in 'XJ Technical Chat' started by Krane, May 17, 2010.
  1. Krane
    Krane New Member
    Bucharest, Romania
    Hey guys,
    I need some info on running a Pirelli MT90 Tube tire on an XJ 650 4K0 from 1982.
    I know the rims on these bikes are tubeless and i wonder if i need to run a tube or i can use it without tube and with a little more pressure to keep the bead seated?
    Regards,
    Bogdan
  2. Krane
    Krane New Member
    Bucharest, Romania
    None of you have tried to fit a tube type tire on a tubeless rim ? :(
    I really like the profile of this tire and also i will be running 60% on road 40% dirt roads, so i need to know if i can fit it without a tube or i need to order one.
  3. MiCarl
    Tube type tires require a tube. Period. Should go on the rim just fine.
    Tubless tires are much less prone to sudden, catastrophic pressure loss. I'd seriously consider finding a different tire.
