carb questions. missing air jet??? help a noob please.
Discussion in 'XJ Technical Chat' started by BlackSpanker, May 27, 2010.
  1. BlackSpanker
    BlackSpanker Member
    Masshole, USA
    So I rebuilt my carbs. boiled them in lemon juice. removed the jets, replaced the mains and pilots. I cant help but notice that it looks like I am missing an air jet, I see the threads in the hole, but there is no jet....
    http://i632.photobucket.com/albums/uu46 ... ethole.jpg
    also on a separate note can someone point out where the airfuel mix screw is I have no idea. thanks.
  2. snowwy66
    snowwy66 Member
    Salt Lake City, Utah
    all 4 of your carbs will look like that pic. that empty hole is for a plate that goes inside. and a screw to go into that hole that holds the plate in. if all 4 of your carbs are like that. then they're all missing that plate and screw.
    others that are more knowledgeable will have to tell you if that plate is important or not.
  3. pauluminous
    pauluminous Member
    Vancouver, BC
    *EDIT* Just noticed ur q wasn't answered yet. The air/fuel mix screw is right next to the "choke" plunger, it might be covered by an anti-tamper cap.
    Bumpty bump.
    Is it or isn't?
  4. marshallnoise
    marshallnoise Member
    I read elsewhere on this site that the Hitachi carbs do not require them at all.
  5. skeeter
    skeeter Member
    Iron Mountain, MI
    i'm told the plates are not necessary - although, i can't help but wonder why they would put them in there if you don't need 'em.
  6. RickCoMatic
    You're OK if you have 2 Air Jets and a Threaded Hole.
    The Threaded Hole is for a Fastener that held a Blanking Plate.
    The Bike goes faster without the Plates.
    Polish the Bores and it runs better, ... yet!
  7. BlackSpanker
    BlackSpanker Member
    Masshole, USA
    not sure if you are sarcastic here. does it matter that the screw is not there? anyone have the location of the fuel mix screw?? thanks
  8. snowwy66
    snowwy66 Member
    the fuel mix screw is on top on the outside located in front of the carb. if you look THROUGH the front side of the carb you will see a hole on the inside top. that is where the fuel mix screw goes through.
  9. BlackSpanker
    BlackSpanker Member
    Masshole, USA
    thanks. so does it matter if that screw is not there?
  10. snowwy66
    snowwy66 Member
    as rickomatic stated. the bike goes faster without the plate and screw.
    if that's the case. make sure all 4 carbs are missing. so they all run the same. if it's just one missing. then replace it. and for kicks and giggles. you can try all 4 pulled out and see if there's a difference.
  11. RickCoMatic
    Remove the Plates.
    See how she runs without the Plates and AFTER you CONFIRM that ALL the Air Jets are in the correct configuration.
    Pilot AIR Jet --> Large Opening --> (O) --> Top
    Main AIR Jet --> Small Opening --> (o) --> Middle
    Empty Threaded Hole
  12. BlackSpanker
    BlackSpanker Member
    Masshole, USA
    thanks what is the stock setting for the screw?
