Need to get rid of alot of parts
Discussion in 'For Sale, Trade/Swap, Wanted' started by yukon1015, May 1, 2010.
  1. yukon1015
    yukon1015 Member
    send me a pm with any parts you need off an 82 XJ650 RJ or a 82 XJ750 seca, for the 750 im even selling the frame, just about everything. Let me know what you need.
  2. Xplicit_XJ
    Xplicit_XJ Member
    Chetek, WI
    Got a round headlight off of either? Maybe and exhaust or gauges?
  3. yukon1015
    yukon1015 Member
    i dont have a round headlight but i do have an exhaust and a set of guages for a 650 seca, i have the guages for the 750 seca but some of the wires have been cut, its not that big of a deal.
  4. Xplicit_XJ
    Xplicit_XJ Member
    Chetek, WI
    Any idea if the gauges would work on a 82 XJ750 Maxim? And if so could you send pics?
  5. rcracerguy
    rcracerguy Member
    Defiance,OH
    got any engine guards?
  6. yukon1015
    yukon1015 Member
    the guages wouldnt work on the 750 maxim, they have a center computer concole in them that the maxims weren't wired for, and i dont ahve any engine guards.
  7. Dezmond
    Dezmond New Member
    Ingerhole Ontario
    what about a fairing for the 750?
  8. XOMBIE
    XOMBIE New Member
    What would you want for the 750 gas tank? Is it in good condition, no holes or major rust?
  9. yukon1015
    yukon1015 Member
    i dont have a fairing for it but i do have a tank, i havent opened it up so i dont know what it looks like inside, i will post some pix as soon as i get a chance.
  10. Nixels
    Nixels New Member
    East Bay, CA
    I just got an '82 XJ650 Maxim. The intake manifolds are cracked and leaking. I fixed one with a little goo, but would prefer a good set.
    Do you have a set for this bike?
  11. yukon1015
    yukon1015 Member
    i do have a set for a 650, let me know if your interested.
  12. Xplicit_XJ
    Xplicit_XJ Member
    Chetek, WI
    Do you know how hard it would be to match up the exhaust and all that to a 82' 750 Maxim?
  13. marshallnoise
    marshallnoise Member
    I am in need of the rectangular headlight assembly. I have the head lamp just fine, but I don't have the box it mounts in or the brackets it mounts to the frame. Do you have those?
    Also, I might need the means by which you attach the front signals to the forks.
    I have an 83 Seca 750 FYI.
    Thanks!
  14. yukon1015
    yukon1015 Member
    i dont think it would be to hard the match the exhaust with the 750 maxim, but then again i have never done it and i have the mounting bracket for a rectangular headlight but i dont have a bucket, the bracket comes with the mastercyclinder
  15. britcan
    britcan New Member
    San Antonio TX
    price on guages fir the 650
  16. koolaid5
    koolaid5 Member
    Chambersburg, PA
    How about pics of the tanks?
  17. LoDollarDave
    LoDollarDave Member
    Edmonton Alberta
    Is the 82 750 Seca equipped with the anti-dive valves on the bottom of the fork legs? If so, what would you want for the valves/valve bodies and lines to connect to the calipers? Mine are completely shot with internal corrosion and are currently disconnected.
  18. hrichard
    hrichard New Member
    How are the carbs on the 650?
  19. Nervace
    Nervace New Member
    You got any parts left for the Seca 750? I am looking for some spares for mine
  20. digitalbroccoli
    digitalbroccoli Member
    sodus ny
    I'm looking for a clutch lever/perch that'll fit a 650. Any chance of having that laying around?
