I need a picture of where the neutral switch is.. I'm stupid
Discussion in 'XJ Technical Chat' started by codydenver, Jun 21, 2010.
  1. codydenver
    codydenver New Member
    MN
    Hey, I have been trying to put my 82 xj650 back together... it won't start for beans! I'm looking for the location of the neutral switch as my Manuel has not arrived yet. Pictures anyone!?
  2. cutlass79500
    lawrenceville georgia
    bottom of motor by shifter sky blue wire phillips screw holds the wire on . its the only switch on the bottom follow the sidestand switch the wire comes off that part of the harness and goes under the motor
  3. SecaRob
    SecaRob Member
    Cincinnati, Ohio
  4. codydenver
    MN
    Awsome...
  5. bigfitz52
    What you need is the location of the safety relay unplug that to confirm your diagnosis (or bypass the neutral switch temporarily.)
  6. yguy
    yguy New Member
    utah
    posted links are broken can you please send me some pictures
  7. yguy
    yguy New Member
    utah
    I know its been awhile but I really can't find it and I need those pictures
  8. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    +1. My engine is apart. The switch is to the left of the oil level sensor in a recessed cavity beside the oil sump. The oil level sensor connector and the neutral switch are in close proximity.
    Gary H.
  9. Polock
    hint, the splined shifter shaft rotates the shifter drum, the switch extends up to touch the drum
  10. k-moe
    Hint #2. If you have a 750, the exhaust collector hides the switch from direct view.
  11. rocs82650
    Middle Tennessee
    Hint#3. It's also hidden on the 650.
    Gary H.
  12. k-moe
    But not nearly as hidden, and it's actually accessible (barely) on a 650 without dropping the exhaust.
  13. rocs82650
    Middle Tennessee
    I'd call that hidden. If you don't drop the exhaust use lots of curse words; they're plentiful.
  14. JaiFer
    JaiFer Member
    Northern Ontario
    On my 650 Seca you have to drop the exhaust. If you don't have a special tool to reach the neutral switch you have to take off the front motor mounts and jack the the engine up and because of the close proximity of the frame I had to ground the walls of a (I think 14mm) socket to get in there. and it is difficult to see. I tried using a mirror, still to difficult to see. Since the oil and gas had been drained I decided to to GENTLY lay the bike on it's side against a cushion and was able to R&R it. To be able to help better you should list your model as there are differences. Best to include in them your signature. Best of luck Jaimie
  15. k-moe
    By accessable I mean tht you can reconect the wire if it comes off or is broken. You definitely can't remove the switch with the exhaust in situ, or without needing to modify a socket to clear the frame.
  16. yguy
    yguy New Member
    utah
    Thanks for help hope I can find it
  17. rocs82650
    Middle Tennessee
    It's there. You'll find it. We'll help until you do.
    Gary H.
  18. k-moe
    But we won't post a picture......because.......reasons o_O
  19. chacal
    We actually have a special little set of tools needed to remove the switch while the engine is still in the frame (and on most models, while the exhaust is still in place, too):
    HCP15718 Aftermarket neutral position switch REMOVAL SOCKET. On many models, it's almost a physical impossibility to remove the neutral switch from the crankcase "well" without removing the exhaust system or removing the engine from the frame.....the left lower frame tube conspires with the exhaust system to make it unbelievably difficult to access the switch. This special "open side" socket is the proper size to squirm through those restricted spaces and make it possible to remove and re-install the position switch without going through a tremendous amount of effort. Standard 1/4" drive socket should be used with a 3" "swivel end" extension bar, or, it's even easier to use when attached to the HCP13516 flexible shaft driver listed below.
    HCP13516 Aftermarket flexible "spring shaft" 1/4" SOCKET DRIVER TOOL, just the thing to use with the HCP15718 socket above to reach the neutral switch. Large plastic handle with 6" long flexible shaft.
    rocs82650 likes this.
  20. rocs82650
    Middle Tennessee
    K-moe you drive a hard bargain. Because like i said...the engine is apart. I was actually thinking you'd have posted one.
  21. k-moe
    Mine is all back together. I could post up a picture of the exhaust collector I guess. I'm sorry that I can't be more helpful :(
    Funny thing: my dryer is currently torn down for maintenance.
  22. rocs82650
    Middle Tennessee
    You're way ahead of me. I'm taking my time. I'll post in my thread.
    Gary H.
  23. yguy
    yguy New Member
    utah
    I guess ,I need to tell you why I need to know where the safety switch. I bought the bike neutral safety switch was working without clutch lever and some wires cut. now that I have new clutch lever put the wires back together. the light comes on and stays on even when you're going down the road unless you disconnect the wiring.
  24. yguy
    yguy New Member
    utah
    Everything that I've read said it's a bad switch right
  25. k-moe
    Yes. Either bad or stuck from sludge buildup.
    Look for the light blue wire near the shift lever, and between the frame rail and the oil pan. Follow it toward the front of the bike. It will terminate at a screw. That is where the switch is.
