1985 maxim x 700 partout
Discussion in 'For Sale, Trade/Swap, Wanted' started by FUZZOFDARKNESS, Mar 13, 2010.
  1. FUZZOFDARKNESS
    FUZZOFDARKNESS Member
    anyone need parts?
  2. FUZZOFDARKNESS
    anyone need any parts. got lots of em
  3. jt1200r
    jt1200r New Member
    Huntingtown,Md
    i need a clutch cable
  4. FUZZOFDARKNESS
    pm sent to jt1200r
  5. stovebolt
    stovebolt New Member
    Shawnee, Oklahoma
    if the wheels will fit an 82 750 maxim then i would be intrested in them.
  6. FUZZOFDARKNESS
    well i'm not sure really, i googled it and got your post on xjbikes. i looked at some pics, they very well might fit, i don't want to give you false hope though, without having both rims here i can't be sure, i sent a pm
  7. FUZZOFDARKNESS
    ANYONE NEED ANYTHING GOT TONS OF PARTS LEFT, I ALSO STARTED RIPPING THE ENGINE DOWN, SO IF ANYONE NEEDS ANY ODDS AND ENDS FROM THE ENGINE LET ME KNOW
  8. lllintothevoidlll
    lllintothevoidlll New Member
    Michigan
    Do you still have the speedometer? Its pretty close to my boyfriend's mileage and his just died today.
  9. FUZZOFDARKNESS
    sorry the speedo and tach weren't any good, gave one away, i think i threw away the other.
  10. lllintothevoidlll
    Michigan
  11. lllintothevoidlll
    Michigan
    Actually I found out I need the speedo gear by the front wheel not the speedo itself.
    Do you still have that and what's your asking price?
  12. superluckycat
    superluckycat Member
    United States of Insanity
    If Billt didn't take the mufflers I'd be interested in the left one if it's in decent shape.
  13. Treads
    Treads Member
    I need the airbox, speedo cable, and tach cover(doesn't matter if it has road rash). PM me a price if ya still have any of em. Thanks in advance.
  14. SoupNazi
    SoupNazi New Member
    Minneapolis
    I am interested in both horns, the front fork assembly, and one rear turn signal.
  15. whitey
    whitey New Member
    Victoria, BC
    hi there
    would you have a cross joint still available, it is the u joint on the rear drive shaft. if so let me know a price thanks steve
  16. FUZZOFDARKNESS
    hey steve, the joint is on its way up there. sent on tuesday. let me know when you get it.
    lots of parts left anyone need anything?
  17. FUZZOFDARKNESS
    does anyone have any XS650 parts lying around? or some 10-11" shocks?
    i would definitely be interested in some trading
  18. MICKD1953
    MICKD1953 New Member
    Do you still have the Petcock? Also the front brake reservoir...???
  19. DIGX1MAXIMX
    DIGX1MAXIMX New Member
    ND
    Do you have the part that the clutch lever and mirror attach to? It clamps on the handlebar right after the "Horn" button cluster and handgrip. Let me know. Thanks
  20. SKRAM
    SKRAM Member
    NY/VT border
    I'm looking for the chrome lever off the rear drum, linkage, and brake pedal.
  21. fixxerr01
    fixxerr01 New Member
    Do you still have either of the mufflers and the plastic chrome that covers the air box behind the chrome "5 Valve " badges ? How huch if so?
  22. FUZZOFDARKNESS
    hey everyone sorry for the delay i have skrams pedal and linkage, but sorry all other items in question are sold. i do still have the chrome covers but they aren't in good shape, if someone wants them send a few bucks for shipping and they're yours.
  23. VASHOVELHEAD
    VASHOVELHEAD New Member
    I'm in need of a complete wire harness with all electrical (CDI BOX,YELLOW STICKER , EXC)
    ALSO NEED THE CARBS IF YOU STILL HAVE THEM THANKS
  24. blazerbash80
    blazerbash80 New Member
    Do you still have the backrest?
  25. FUZZOFDARKNESS
    HAVE THE YELLOW STICKER CDI/TCI
    DON'T HAVE THE BACKREST FROM THE 700, I DO HOWEVER HAVE ONE FROM AN 81 YAMAHA XS650 AND ONE FROM AN 80 HONDA CM400 WITH REMOVABLE PAD, ALSO HAVE LUGGAGE RACK AND WINDSHIELD FROM THE CM.
    IF ANYONE NEEDS AN ENGINE/TRANS OR INTERNALS I HAVE ONE MINUS THE HEAD. HEAVY AND IN THE WAY.
  26. kvcobra
    kvcobra New Member
    I PM you about the left side cover. Also possibly the rigt horn bracket if it is still there. Thanks.
    K.
  27. FUZZOFDARKNESS
  28. FUZZOFDARKNESS
    cheap cheap cheap
    come and get it!!!
  29. fezzter
    fezzter New Member
    Not here
    Headlight and bucket?
  30. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Handlebars?
  31. malibooman
    malibooman Member
    Dryden, Washington.
    I would like the rubber mount for the rear of the gas tank & throttle cable,brake lever. I'm trying to restore a XJ750XN,only has 23000km on it but it sat outside way too much.
  32. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Hey FUZZ check your PM's
  33. BillB
    BillB Active Member
    Tulsa Oklahoma
    i need a big gas tank
  34. FUZZOFDARKNESS
    sorry for the delay. most items mentioned are sold or trashed. headlight and bucket available. same for valve cover. pms sent
    if anyone needs internal engine/trans parts you should let me know, tripped over the chuck of metal on the cellar floor the other day. hate to throw it away but not sure how long before it happens again.
  35. FUZZOFDARKNESS
    update scrap metal run this weekend, i need to get this stuff gone. if you need any engine internals, rims or any larger parts, let me know asap. so many parts!
  36. FUZZOFDARKNESS
    100 bucks buys everything i have left, you will have to pick up northeast pa near wilkesbarre , near rt. 80, engine/trans minus the head,cdi, ignition with key, so many electrical components, wheels, brakes, cables, all kinds of odds and ends, if you don't see it sold in the thread I may still have it. to much to list, if someone is really interested i will try and post a quick pic, if not picked up soon i will keep but everything must be relocated. honestly this is a great deal if your in/near pa and have a water cooled maxim, if chacal was closer i'd just send him the pm. let me know before i relocate it all, 100 dollar deal is only good if i don't have to move the stuff. i even have a nice repair manual.
  37. jwxj700
    jwxj700 New Member
    I just need muffler end caps some kid took off email friforme@yahoo.com i have 85 xj700n ph.# 513-227-1280 do you have the gas cap i gotto look at shipping cost idont no what else on the water cooled might work may be back rest bar if not gone need to no
  38. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    Rear shocks still available?
  39. FUZZOFDARKNESS
  40. FUZZOFDARKNESS
    sold everything i had today. i'm sure it'll be up here again under someone else's name. thanks to everyone that was interested, thanks to everyone that bought stuff, sorry i had to kill the bike in the first place. you can't save them all.
  41. vanillaice
    vanillaice Member
    How much would you want for the soledoid assembly? How much for the starter motor assembly? Is the sight glass on the brake fluid reservoir clear and in good shape? If so, how much would you want for the brake fluid reservoir?
    thanks!
  42. xjakabobberann
    xjakabobberann New Member
    pm sent about motor
  43. Dannymax
    Dannymax Member
    East central NY
    Is the left side horn available? Thanx
  44. Dannymax
    Dannymax Member
    East central NY
    Or even just the mounting bracket?
  45. MiGhost
    MiGhost Well-Known Member
    If you read the final entry on page six you will find your answer.
    This post has been dead since 12/30/10.
    Ghost
  46. hogfiddles
    hehe....just me and the ghosts hanging out here.....
    Dave
  47. paintballknight
    paintballknight New Member
    Do you have a right side cover (plastic)
  48. Cdoug
    Cdoug New Member
    Ottawa, ON. Canada
    I`m also interested in the 5-valve covers if the other guys pass on them.
  49. hogfiddles
    Once again........it's a dead thread--------
    dave
  50. tom66
    tom66 New Member
    pa
    Are carbs still for sale
