Clutch lever perch relay switch
Discussion in 'XJ Technical Chat' started by capthowdysmember2003, Jul 11, 2010.
  1. capthowdysmember2003
    capthowdysmember2003 New Member
    WV
    What is the exact function of the switch under the clutch lever perch on a '93 XJ? I've googled the frikkin' thing for the last hour and can't get a solid answer.
  2. capthowdysmember2003
    WV
    Anybody know what thats for? I'm still drawing a blank. All the parts lists I've found just label it "Switch".
  3. RickCoMatic
    Safety Circuit Item
    Switch sends info to Safety Relay indicating Clutch Lever is Pulled or Not.
    In Neutral the Relay does not need the info.
    In Gear ... The Starter will Not Engage unless the Lever is Pulled.
  4. capthowdysmember2003
    WV
