poor take off acceleration
Discussion in 'XJ Technical Chat' started by frankenbiker, Jul 11, 2010.
  1. frankenbiker
    frankenbiker Member
    gobles michigan
    Hi gang, need to pick your brains. I'm experiencing poor acceleration taking off from a standing start,. after a second it really kicks in like it should. I'm replacing my boots tomorrow, I cleaned my air filter yesterday and replaced the plugs. Any ideas? I've looked in the search but nothing that deals with this problem exclusively.
  2. yamaman
    yamaman Member
    Staten Island, NY
    well that's your pilot circuit. if the carbs are clean it could be a sync thing. let us know what carb work has been done. 99.9% carb related
  3. mlew
    Its time for carb cleaning and sync. Pilot circuit and carb slides most likley need attention. Search the site for carb cleaning.
  4. snowwy66
    snowwy66 Member
    Salt Lake City, Utah
    if he's replacing the boots. then i'm guessig they're all cracked. thus sucking in air. VACUUM LEAK.
    get the new boots on and go from there. did you get new gaskets too?
    oh, wait. you didn't specify if you was putting on intake boots OR air filter box boots.
  5. frankenbiker
    frankenbiker Member
    gobles michigan
    I'm putting on the carb to head boots, yeah theres a lot of vacum leak there, yes I got new gaskets. This is great, while I got the rack off I'll clean and sync. good advice thanks guys.
  6. tibor
    tibor Member
    Saskatoon, SK CANADA
    is it better when you turn the choke on? simply replacing those boots could solve your problem if they are leaking bad enough. can't hurt to clean and sync the carbs though but don't let carb cleaner sit on any of the rubber parts for any length of time, it will melt them!
    cheers,
    Trev
  7. frankenbiker
    frankenbiker Member
    gobles michigan
    replaced the carb to head boots tonight. Helped a lot, but I think I still need to sync. The carbs were rebuilt last year, and bench synced, but I put a newer engine in afterwards so I believe I need to re-sync. Bike runs so much better, better acceleration on take off, better at speed, great idle, and don't have to choke the hell out of it to start. I'm slowly learning more and more thanks to you guys. I really appreciate the help and I'll let you know how things go as I progress.
  8. handyman
    handyman Member
    Had the same problem. Synched the carbs on the bike and adjusted fuel mixtures and resynched. You wont believe the response difference, it will feel like a new bike.
  9. bigfitz52
    Start by adjusting the valves.
