Cam Question
Discussion in 'XJ Technical Chat' started by todd, Jul 14, 2010.
  1. todd
    todd Member
    Irvine,Ca
    I just got done rebuilding my 1980 xj650. I set the motor top dead center and lined up the cam marks with arrows. I checked the commpression and only have 85psi in each cylinder.I used seating compound on all the valves and checked each one with water and none of them leaked. I honed the jugs and checked the ring gap and was well within operating standards. The bike used to belong to a mechanic who had passed away and it was running 15 years ago when it was parked. The question I had was there was a mark on the rotor that was not top dead center that someone had put and wanted to know how to tell that someone put a different performance cam vs stock. I am weary to set that as TDC because I do not want to bend my valves. Any ideas?
  2. c21aakevin
    c21aakevin Member
    Macomb, MI
    I have the same problem. Checked the cam several times and rolled it over by hand to be sure that the valves aren't hitting. I checked the mark and did the screwdriver in the plug hole trick - both showed TDC, and cams were correct.
    My compression is about 90 on all cylinders - with new rings. I am going to put a couple hundred miles on it, change the oil and recheck the compression to see if it comes up.
    It runs fine. The more I ride it, the more power it seems to have. It may be that the rings need to seat.
    It had more compression before the build. - I was thinking it was my gauge, now I am thinking it is normal
  3. tibor
    tibor Member
    Saskatoon, SK CANADA
    sounds like you are doing everything right. as kevin mentioned, likely the rings just need to seat. they say not to use synthetic oil for the break-in period because it lubricates too well, you actually want the rings to wear into place for a better seal. after the break-in period, synthetic is often preferred to protect your investment.
    cheers,
    Trev
  4. wizard
    check the compression wet, it will tell you if the problem is valves or rings.
  5. bigfitz52
    You did fit new rings, right? If you honed the cylinders, it should have been in preparation for new rings.
    Just checking...
  6. RickCoMatic
    You did have the Throttles Wide-Open during the Compression Test, ... right?
    (( I have seen "Other" Marks in the the Crank Rotor. I think the PO marked the Rotor to compensate for the FLIMSY Pointer getting bent or bumped out-of-place. And, rather than move the Pointer, ... scratched a new Visual on the Rotor. ))
    Check to see that your TDC Marks all line-up.
    Let's hope your situation is that your are dealing with an Engine that needs to be Bedded-in.
    Run "Break-in Oil" for 500 Miles.
    Don't exceed rpm's -- 50% of the Limit for 500 Miles.
    Change to Operating Oil.
