86 XJ700XS K and N Air Filter
Discussion in 'XJ Technical Chat' started by jimwrixon, Dec 9, 2006.
  1. jimwrixon
    jimwrixon New Member
    CA
    Has anyone changed their original paper element filter to a K and N filter on their 86 XJ700XS?
    What were the results? Did the carbs need readjusting?
    Let me know-Jim
  2. welderflame
    welderflame Member
    Colorado
    I have a Uni-filter(foam) on my 86 no jetting required and it works great.
  3. OU812didntU
    OU812didntU Member
    K & N seem to be nice filters but not worth the hassle to me if you have to re-jet your carbs or experiment with re-jetting. I also have a Uni-Filter and i can clean it when it gets dirty with no problems and no messing around.
    and Uni`s are allot cheaper than K & N.
  4. Danilo
    Danilo Member
    Vancouver canada
    NO rejetting req'd for a simple K&N Air filter swap :)
  5. Dispatcher
    Dispatcher Member
    New York, USA
    I have both the Uni foam and the K&N for my xj550. Both work with the stock air box and claim that no rejetting is necessary. When I first got the K&N I installed it without oiling it first and the bike ran way too lean. After properly oiling the K&N it still seems to run a bit lean, so I just put the Uni back in.
