SWING ARM nut size on MAXIM X .....?????????????????????????
Discussion in 'Hangout Lounge' started by littlegiant, Jul 25, 2010.
  1. littlegiant
    littlegiant Member
    Toronto, Canada
    Anybody have info as to what size NUT is for the Swing arm. I thought i will open it today..and i had to quit as the biggest i had was 24mm and it doesnt fit...XJCD doesnt say anything. Have to go buy the right size socket..thanks in advance.
  2. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
    Once you get over 20mm, a lot of the "imperial" sizes will fit close enough to work if you have a set.
    I'll have to go measure for sure but my biggest metric is 19mm and I put enough of them together now so I must have had something that fit.
  3. chacal
    27mm (about 1-1/16th inch) is the size your seeking.......
  4. F.H.
    F.H. Member
    California
    Re: SWING ARM nut size on MAXIM X .....?????????????????????
    27mm indeed. I just bought one today from autozone for 8 bucks. I dont think any regular set will have anything that big... u'll have to buy it separetly.
    FYI All Japanese products will require and use metric tools
  5. littlegiant
    littlegiant Member
    Toronto, Canada
    Thanks guys.
