Idle Adjustment
Discussion in 'XJ Technical Chat' started by popeye47, Aug 4, 2010.
  1. popeye47
    popeye47 New Member
    Vancouver Canada
    Which direction do I turn the idle adjuster to raise the idle ? Also whats the deal with the choke having to be on for quite some time before theres any chance of idling when its off?
  2. andrewlong
    andrewlong Member
    Cumming, GA
    Turn it clockwise to raise the idle -- that screws it in and opens the venturi valves
  3. popeye47
    popeye47 New Member
    Vancouver Canada
  4. andrewlong
    andrewlong Member
    Cumming, GA
    Not sure about the choke though. When is the last time the carbs were cleaned?
  5. sushiplease
    sushiplease Member
    can someone post pictures of where the idle adjuster is? please? =)
  6. 1904xj
    1904xj Member
    San Diego CA
    Its on the carb rack in the middle it sticks out like a sore thumb. You have to do this when you engine is warm so wear gloves when you reach in the for the adjustment. The starter motor is right under it. Again clockwise makes iddle rise counter clockwise makes it drop.
  7. andrewlong
    andrewlong Member
    Cumming, GA
    ^ yep yep
    Pic just in case:
  8. sushiplease
    sushiplease Member
    couldn't you at least post a larger clearer photo :p JK Thanks!!!
  9. popeye47
    popeye47 New Member
    Vancouver Canada
    Whats the ideal idle setting, Mines at 1100 is this ok
  10. andrewlong
    andrewlong Member
    Cumming, GA
  11. andrewlong
    andrewlong Member
    Cumming, GA
    When I can get mine to actually idle, it sits at about 1100. Not sure if it's correct, but it works for me!
  12. Lou627
    Lou627 Member
    Queens, NY
    LOL andrew
  13. marshallnoise
    marshallnoise Member
    Epic picture is epic!
  14. chacal
    That's great! :D
  15. bhikku
    bhikku Member
    SLC
    ugh i can't wait until i fix my tach so i can actually see what i'm idling at. :/
  16. gratscot
    gratscot Member
    Well I know the idle for my xj650j is 1050 (I found that on on of the side covers) However sense the bikes are older its ok to have it a bit higher unless everything is in really great condition.
