XJ600 ignition issues
Discussion in 'XJ Technical Chat' started by themightyrick, Jul 8, 2010.
  1. themightyrick
    themightyrick New Member
    hi guys just bought my self my first xj600, it was sold as a non runner as someone had tried to steal it. fixed the wires that had been broken tried to turn it on but i wont start.
    all the lights come on and the strater motor is turning over but there is no spark at the plugs. i have tested all the cables coming from the plugs to the ignition coils and from there to the fuse box etc all fine.
    i have tested the resistance on the ignition coils the primary resistance was fine but the secondary one was twice what it says in my haynes!
    i was just about to order a new set when i read a post on a differnt forum, the guy said that he had the same problem, tested the coils and got the same result. he then tested the coils on a working diversion and got the same result on that!
    so i am a bit lost really and could do with some advice, feel abit cheeky asking for advice on my first post but i really need your help.
  2. sledchuck
    sledchuck New Member
    finger lakes,ny
    what did you find out i have simular problem.primary is fine but secondary nothing?
  3. markie
    markie Member
    Suffolk, England
    You need a wiring diagram. If it is a pre diversion, there is a link on this site but if it is a divvy, google "Free download" and there are some on the net. I downloaded one accidentally - but the file is too big to email.
    Earlier xj's will not fire if the side stand switch is not clear - it takes the power away from the tci ignition, I don't know if the divvy is like this but a wiring diagram will tell you.
    If you get stuck, PM me your email address and I will send you the wiring diagram as a couple of .bmp files.
    Just reread your message - have you got the Haynes manual already?
    Tip: add your location and model of bike to your signature - mileage too - and you may get more accurate responses.
  4. themightyrick
    hey sorry for the delay, dont check my email often enough, changed the battry and the ignition coils, and got a spark! still didnt start :( found out the pick up coil was f*cked so changing that now aslo drained the carbs and put some V power in it for that extra boost. ill let you know if it works
