wheel swap
Discussion in 'XJ Modifications' started by neobudda, Aug 14, 2010.
  1. neobudda
    neobudda New Member
    Des Moines, IA
    Just picked up my 82 xj750 seca. It was to tall so I shaved the seat, but still pretty tall. I know that the maxims have 16 inch wheels vs the 18 inch ones on mine. Question is, should I get a wheel from a 650 or 750 maxim. I know the brakes on the 650 are a bit smaller, so I'd have to use shoes and a hub from that bike, right? Is the 750 maxim the same way? Thank you in advance
  2. streetbrawler750
    streetbrawler750 Member
    Minnesota
    750 max outta do the trick
  3. neobudda
    neobudda New Member
    Des Moines, IA
    So the brakes are the same on the 750 maxim as the 750 seca? That's awsome, thank you
  4. streetbrawler750
    Minnesota
    Ya I believe so, 99%
