First day off in a while and need help on some bike repairs
Discussion in 'XJ Technical Chat' started by Chuck25, Aug 15, 2010.
  1. Chuck25
    Chuck25 Member
    Well tomorrow is my first day off in a while and I need to do some work on my 85 yamaha 700 maxim.
    One thing I need to do is an oil change is valvoline motorcycle 20w-50 wait ok and how much.
    Second I need to change the front brake pads
    Is dot 3 ok for fluid
    Second the rotors seem okay to me they are not warped and I put a caliper on them and came up with 1.85 on both is that thick enough.
    Here is the best pick I could get of the rotor
    This is what I found troubling when I was checking the rotors I noticed the brake line was split. So that needs to be replaced. If so am I looking at the right part on bike bandit. Are brake lines really $90 8O If so is there a better place to look, Thanks guys here is a not so great pick of the break line
  2. schmuckaholic
    California
    It should be, AFAIK.
    Oh, Len... wherefore art thou Len...
    Go talk to Chacal. I'm looking at an old list I made up for him, and it shows that line has being about $45 for the rubber. (Add a few bucks for stainless.) Even figuring subsequent price increases, there's no way he'd be charging you anywhere near $90.
  3. chacal
    Chuck, we carry both the original style rubber and DOT-approved braided stainless steel brake lines for you bike, drop us an email or send a PM via the website message system for more info......
    1.85 (mm?) is far too thin for the rotors......you may wish to re-measure and confirm!:
    The minimum thickness for original rotors is as follows (these specifications do NOT apply to aftermarket rotors). The maximum allowable "runout" or warpage is 0.15mm high-to-low for all models, all rotors:
    4.5mm for all XJ550 models, all XJ650RJ Seca and XJ650 Turbo models, all XJ700 models, and all XJ750 models.
    DOT3 brake fluid is just fine.
  4. snowwy66
    snowwy66 Member
    Salt Lake City, Utah
    dot 3 was the only thing around back in them days.
    dot 4 didn't come out untill the mid 90's. it's basically a new and improved dot 3 replacement. and can be used in place of dot 3
  5. clipperskipper
    clipperskipper Member
    Cape Cod, MA
    Perhaps your units are standard, and not metric? The pics are good I 'd replace the chaffed hose asap.
  6. Chuck25
    Chuck25 Member
    Re: First day off in a while and need help on some bike repa
    Yea I used standard. Opps I converted it and I am good. Thanks alot for the pm chacal. I will be buying all new brake lines and washers. Infortunatly for all those goodies I will have to wait a few paychecks :cry: but I will be using your buisness I am glad to see there are parts still out there.
  7. SovereignDragon
    SovereignDragon Member
    Leavenworth, KS
    I've spent a lot of money with chacal and have been extremely pleased with the quality of parts and service. I happily recommend him, and welcome to the site.
  8. Chuck25
    Chuck25 Member
    Okay so I found the oil filter is the plug under and behind it? thanks guys
  9. bigfitz52
    The oil drain plug is under and to the rear of the oil filter; it's on the very front of the sump. 19mm IIRC.
