Starter problem?
Discussion in 'XJ Technical Chat' started by jcboyd, Aug 21, 2010.
  1. jcboyd
    jcboyd Member
    Dickinson, Texas
    I have a 1983 xj 750 maxim.
    When I tryto start it it makes a rattle sound.
    Sometimes it will engage and start immediately, sometimes it takes awhile for it to start.
    I believe it is a starter problem.
    Do I need to buy a whole starter or can I buy solenoid seperate from the starter?
  2. bigfitz52
    The solenoid IS separate. It's actually just a relay.
    Your problem is probably not the solenoid, however. More likely the starter, starter clutch or electrical connections. It could be as simple as the wrong oil.
  3. jcboyd
    jcboyd Member
    Dickinson, Texas
    Thanks for the info.
    Wrong oil will do that?
    what about old oil or low on oil?
