mufflers
Discussion in 'XJ Modifications' started by jt1200r, Aug 4, 2010.
  1. jt1200r
    jt1200r New Member
    Huntingtown,Md
    whats the best and easiest thing to do to these mufflers to get more sound and not have to change any jets in the carbs? 85 X
  2. iwingameover
    iwingameover Active Member
    sportster mufflers. Cheap and easy.
  3. jt1200r
    jt1200r New Member
    Huntingtown,Md
    what about drilling out the center plug
  4. Babylon
    Babylon Member
    Somerset, United Kingdom
    What sort of work is required to get them to fit please dude?
    One of my cans on the XJ700 Maxim X has rusted right round and is only hanging on by the bolt to the frame!
    Need a quick change of cans which isn't going to cost the earth as can't get the correct Maxim cans here in the UK :(
    Any one know what other Yammi cans would fit straight on without mods please as need to do this ASAP as I use the bike for work.
    Cheers .... Babylon 8)
  5. iwingameover
    Possibly a reducer if thee diameter is different and a clamp or weld it on.
  6. Babylon
    Babylon Member
    Cheers for the speedy reply ;)
    Just spoken to one of the guys in my bike club who's a Harley boy & he has a pair of Sportster mufflers knocking around that aren't in too bad a condition & he's going to bring em home from the workshop on Monday nite and do any mods needed to fit them to my bike for the equvalent of $20 and a few pints!
    Any idea what the dia of the pipe out of the collector is please? ! 1/2", 1 3/4"?? Then I can give him the heads up :)
    Cheers again 8)
  7. iwingameover
    my 650 had a 1-3/4" on the 4-1. You can measure with a tape measure.
  8. Babylon
    Babylon Member
    Stuck a pair of Harley Screaming Eagle cans with no baffles on for a stand in till we build a new pair. Collector accepted 1 1/2" & had to make up collars as the Harley cans were 1 3/4".
    Can't get too many spares for the XJ700 MaximX over here in the UK, so my Secretary in the bike club who helped me with the HD cans is going to make me a pair of pipes with baffles in and turn outs or turn downs.
    Should look the business & will post up pics when they are on.
  9. hellbilly
    hellbilly Member
    st. louis
    I drilled 8 holes in the end of mine going in a circle around the inside of the cone. It gives it a great sound especialy when accelarating.
  10. Babylon
    Babylon Member
    I already had 5 holes drilled in the end of my cans & yes agree they do sound the business .... the only reason I had to change them wasn't because it wasn't load enough, it was because the original can rusted through and needed replacing ASAP to keep me on the road as I use the bike for getting to work as well as everywhere else! The stand in pipes are totally unbaffled and are so loud that only the pensioners with their hearing aids turned off don't turn round to see what's coming down the road, even in 30mph areas! :D
    Will get a re-tune once the replacements are made & fitted, as at lower revs it runs a bit rough, but blasting up the motorway at 110mph going to work in the mornings, it sounds like sweet (load) music ;)
  11. Babylon
    Babylon Member
    Here's what happened to one of the cans
    The two pieces that should have been one!
    The collared (and baffleless) Harley Screaming Eagle pipes that are the stand in's until we make the new pipes ;)
  12. koolaid5
    koolaid5 Member
    Chambersburg, PA
    those are screamin eagles? Mine don't look like that.
  13. Babylon
    Babylon Member
    That's what Harley Dave told me ... Think the central bit (now painted black) isn't original, but the silver ends are from Screaming Eagles?!
    Inly going on what I'm told as I'm not a Harley man ;)
