no oil in gearbox?
Discussion in 'XJ Technical Chat' started by secaman, Aug 9, 2010.
  1. secaman
    secaman Member
    guatemala, central america
    i thought this bikes used only engine and drive shaft oit,
    do they use a separate gearbox oil?
    i found a plug in the rear left side and
    u could see rusted gears in there.
    did i miss something and shouldve put oil in there?
    i cant find anything about it in the manual,
    pls let me know whats going on here.
    ty
  2. wizard
    The engine & transmission share oil, can you show us where this plug is on this picture?
  3. RickCoMatic
    There should BE Oil in there.
    That's the Middle Gear Exchange.
    The Lubrication System is supposed to Oil the Middle Gear Exchange from the Supply of Oil Pumped through the System by the Oil Pump.
    Finding NO Oil in there is unusual.
    There's usually about 65ml. in the cavity.
    That Drain Plug IS NOT the Engine's MAIN Oil Drain Plug.
    The MAIN Drain Plug is on the Front of the Engine.
    Above the Oil Filter Dome.
    On the Sump, ... above the Exhaust Collector's middle Inlets.
    19mm Hex Plug (Often with a Cross Head Screw in its' center.
  4. TIMEtoRIDE
    I've measured about 200 ml
    http://www.xjbikes.com/Forums/viewtopic/t=23688.html
    Below the filter housing, in a hard to reach area.
  5. RickCoMatic
    Editors Note:
    The preceding Post Quotes me "Out Of Context"
    And is INCORRECT!
    It's NOT hard to reach.
    It's Easy to reach, ...
    And, ... WILL be found, ...
    "On the Sump, ... above the Exhaust Collector's middle Inlets.
    19mm Hex Plug (Often with a Cross Head Screw in its' center."
    On ... the ... sump.
    Above <-- the --> Exhaust Collector --> middle Inlets.
    19mm Hex Plug.
    (Often with a Cross Head Screw in its Center.)
    Pretty specific.
    Should have been included in the quote.
    This ain't FOX News.
  6. secaman
    secaman Member
    ok got the pic!!
    sry for late but i sold the bike.
    the new owner complained bout the oil,
    so i told him its the same as the engine oil.
    hope hte pic is ok.
  7. secaman
    secaman Member
    bump...
    he said he took out this screw and saw rusted gears
    and no oil in there, should there be oil there?
    he put oil in that hole and said the bike is much smoother
    and the gears stopped making noise.
    well guys i wont see u as much as id like anymore ;(
    still this is the best xj site, and will check it when i need to!!
    i bought klr650 which suits my dual purposes better!! ty
  8. iwingameover
    iwingameover Active Member
    that's not a fill hole.
    It's just a bolt. If he saw a gear it would have been the shaft drive gear. Maybe it is rusted maybe not but oil doesn't go in that hole.
  9. RickCoMatic
    He must have seen just threads.
    That Bolt holds the Cases together.
  10. iwingameover
    I wonder how much oil he got in there then?!
  11. secaman
    secaman Member
    hmm i guess my question is,
    should there be oil in there?
    and if so where does the oil come from?
    it should be the same engine oil right?
    dunno how much he put in.
  12. Robert
    Peaceful roads Secaman, shoot some pics of the new ride!
    I'm curious as to why you have a picture of one of the output flang shaft clamp/rear case bolt with an arrow pointing to it? I seem to have missed the relevence.
  13. secaman
    secaman Member
    well u could've rad the above,
    but here goes:
    the new owner complained there was no oil in gear box.
    he said he took that screw off and saw rusted gears and no oil in there.
    so i told him the engine oil is the same as the gear box oil,
    so if it had oil in sifght glass there was nothing to worry about.
    then he told me he put oil in there, and the noise in the gears stopped,
    and now the bike is muuch smoother and quieter.
    so should there be a separeta oil in that screw i pointed at?
    there u go the whole story!!
    ps. ill try post some pics of the klr, though i miss the seca for the street .. ;(
  14. Robert
    Ahh... Thank you for explaining it. I see I think. I don't remember seeing anything under that bolt when I had my 750 engine apart. Something isn't making sense to me... it's got to be me.
    Oh well, you got the problem fixed and the bike is happy. That is what matters.
    Do drop in whenever you are in our neck of the woods, I'd love to show you the sights here.
  15. secaman
    secaman Member
