You don't see many of these about.
Discussion in 'Other Motorcycles' started by wizard, Aug 18, 2010.
  1. wizard
    Cable opperated disc brake, 1977 Kawasaki KZ200.
  2. schooter
    how does that work wiz? the cable attached to a lever that turned a coarse threaded screw or somethin?
  3. wizard
    I'm still trying to work it out Schooter, it's an enigma.
  4. markie
    markie Member
    Suffolk, England
    if it is like 80's lightweight Hondas, it will have a ratchet so as the pads wear the ratchet will take up the slack.
  5. bigfitz52
    My kid's minibike has one. In it, there is a lever that rotates a "cammed" surface that presses on a couple of plungers that press on the pad. Each side of the "cam" pushes its own plunger.
  6. wizard
    No cams & plugers, Fitz, but we do have 3 ball bearings??
  7. MiCarl
    I've seen 3 ball bearings in cable operated clutch actuators. On those the balls go into ramped slots. As the cage rotates the balls expand the assembly. Might be something similar in your caliper.
  8. wizard
    You get the cigar, Carl.
  9. grmeyers
    grmeyers Member
    Asheville, NC
    That's exactly the way my 85 HD clutch works
  10. kirkn
    kirkn Member
    Orlando, FL
    I had a KZ200 ~18 years ago. I rebuilt the brake too. Nothing to it. I also had a Honda CB200, which are about the only two bikes that ever came with a mechanical front disk brake like that. (Oh, the Honda CB125 had it too for a few years...)
    Kewl.
    Kirk
  11. wizard
    I put it all back together, it works as Carl said, it doesn't have a great deal of 'throw', just a couple of mil, must be enough I guess.
  12. RickCoMatic
    I wish he'd have placed all those antique bits away from the coupons so I could see the prices of the fruits on sale.
    If you want to have some fun with somebody, ... the next time you see a Pile of Bits like that Mechanical Caliper all laid-out ... find and old Spring you saved from a Brake Wheel Cylinder and drop it in with the rest of the Parts.
    You have more fun watching everybody try to figure-out just where that spring goes than you will trying to figure-out how to solve this puzzle.
    (Don't click on this link unless you have at least 2 Hours to figure-out what the SIX opening moves out of the necessary 84 it takes to solve the puzzle.)
    http://www.puzzleworld.org/slidingblock ... quzzle.htm
    Don't say I didn't warn you.
  13. SovereignDragon
    SovereignDragon Member
    Leavenworth, KS
    Rick you bastard. Can't....stop....puzzle....
  14. 1904xj
    1904xj Member
    San Diego CA
    That puzzle made me feel like a dumb shit....lol
  15. schooter
    here, i figured it out and got it for you :roll:
    1: A down
    2: 1 left-left
    3: 2 up
    4: 3 up
    5: 6 up-left
    6: 3 down-down
    7: 2 right
    8: 6 up-up
    9: A right
    10: 4 up-up
    11: 5 left
    12: 7 left
    13: 8 left-up
    14: 7 right-right
    15: 5 down
    16: 8 left-left
    17: A down
    18: 6 down-left
    19: 2 left
    20: 3 up-up
    21: A right
    22: 8 right-up
    23: 5 up
    24: 7 left-left
    25: A down
    26: 8 right-right
    27: 2 down
    28: 1 right
    29: 4 up
    30: 6 down-left
    31: 2 left
    32: 8 left-up
    33: 3 down
    34: 1 right
    35: 2 up
    36: 6 right-right
    37: 2 down
    38: 4 down
    39: 1 left-left
    40: 3 up
    41: 8 up
    42: 6 up
    43: A up
    44: 7 right-right
    45: 5 down
    46: 2 down
    47: 6 left
    48: 8 down
    49: 1 right
    50: 4 up
    51: 2 left
    52: A left
    53: 3 down-down
    54: 8 right
    55: 6 right
    56: 1 right
    57: 4 right
    58: 2 up-up
    59: A left
    60: 6 down-down
    61: 8 left
    62: 3 up
    63: 6 right
    64: A right
    65: 2 down-down
    66: 4 left
    67: 8 left-up
    68: A up
    69: 6 left-left
    70: 7 up
    71: 5 right-right
    72: 6 down-left
    73: 5 left
    74: 7 left
    75: 3 down-down
    76: A right
    77: 8 down-down
    78: 4 right
    79: 2 up-up
    80: 8 left-down
    81: 2 down
    82: 4 down
    83: 1 left-left
    84: A up
  16. iwingameover
    iwingameover Active Member
    Glad to see all that study time is going to good use schooter
