help!! ignition wires
Discussion in 'XJ Technical Chat' started by streetfighter89, Aug 28, 2010.
  1. streetfighter89
    streetfighter89 Member
    jackson, mi
    there are 2 white with red wires running off the ignition, on my xj does anyone know where those are suppose to run too? need help thanks for any input guys
    83xj750r seca
  2. msherrow
    msherrow New Member
    Jacksonville, FL
    I've got a factory manual for an 82 750 J that says those wires go to the kill switch.
  3. Polock
    battery monitor, if you don't use it keep the wires handy they're a isolated circuit you can use for whatever you need
  4. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    The two white wires with red tracers are for the battery sensor to the system monitor. If you chrck at or near the battery you'll find one wire with a female bullet type connector. That one goes to the battery sensor. The other one goes into the headlight and is in one of the connectors going into your instrument cluster.
    MN
  5. streetfighter89
    jackson, mi
    alright thanks guys that makes sense and since i no longer have a factr gauge cluster and just a single speedo that would explian why that one wire isdisconected.
