wiring chop up!
Discussion in 'XJ Modifications' started by kitman, Aug 30, 2010.
  1. kitman
    kitman New Member
    i just bought this 81 550, and i decided to redo the wiring witch was hacked but i guess i didnt know it was this bad, i have spent some time on it and haven got anywhere. the last owner really hacked it up there is sh!t spliced everywhere. i have wiring diagrams off this site but im not to savy with the wires. all i want is the bare minimum for the bike to run, headlight, tail light, blinkers and a simple on-off switch. is there anyone that can help. also there are a few items i cant figure out what they do or where they came from.
    I dont know what these are.
    The bike after the bob almost there
  2. Orange-n-Black
    Memphis Area
    What a bird nest! Find the PO and slap him. :lol: Sorry can't help with the wiring but I'm liking the bars and the sissy bar. :twisted:
  3. kitman
    kitman New Member
    thanks man , i think i just solved my problem i bought a full harness of ebay i will keep everyone posted on the bike!
  4. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Half the stuff is missing that the stock wires went to. You need to find someone with a similar bike and see what you can do from there.
    MN
  5. streetbrawler750
    streetbrawler750 Member
    Minnesota
    http://www.currentobservations.us/image ... Series.jpg
    You probly didn't need to buy a complete wiring harness, everything on my bike is new (old recycled) wires except the regulator, starter and coils, I just found out what the bike needed to run and kept that and threw the rest in a box to be stripped and color coded for the next project.
  6. streetbrawler750
    Minnesota
    BTW that is a 650 or 750 not 550, the 550 is chain driven, check for displacement inbetween the exhaust header towards the top it will say.
  7. kitman
    kitman New Member
    i was told it was a 550, but now that you say that i did notice that the drive was different. Will that make a differecnt for the harness i bought?
  8. 1904xj
    1904xj Member
    San Diego CA
    I dont see it working... wiring on each model is slightly differrent.
  9. kitman
    kitman New Member
    damn im back to square one
  10. streetbrawler750
    Minnesota
    Weelllllll I wouldn't go back to square one the main things you need are the plugs from/to rectifier regulator, pick up coils, tci, and that kinda stuff. I am ready to help you wire that bad boy, cuz I have done it myself, and I am on here everyday pretty much, it isn't rocket science. You just have to remain calm when faced with a can of colorful spaghetti staring at you.
  11. Orange-n-Black
    Memphis Area
    At least you have different colored wires, it could be worse. :roll:
  12. kitman
    kitman New Member
    Thanks alot man, i am just doin little thing for now. untill i have the time to dive back into it i will def. let you know thought. is there any thing i should start with first?
  13. Robert
    There is a post somewhere on the forums for a completely minimum wiring setup with schmatic. You might try to find it. I'd be interested in your leftovers (the connectors mainly).
  14. poprider
    poprider Member
    Seattle, WA
    Where does the key factor in on that diagram? do I need more than just the red/white lines from the key?
  15. streetbrawler750
    Minnesota
    The key in that diagram is labeled on off, basically you feed hot from the battery through a fuse to the rect. reg. then to the on side of the key. Rect reg is hot always. The key is shown turned to the park position on this diagram. Wich is something I didn't use on mine.
  16. kitman
    kitman New Member
    no wiring updates yet but i went hard tail! looks alot better that stock frame
  17. kitman
    kitman New Member
  18. Orange-n-Black
    Memphis Area
    Nice job, but you might want to put a strut on the the bottom along the shaft to the drive pumkin for extra strength.
  19. tensor8686
    tensor8686 Member
    diggin the bike man pretty interested to see how it goes yamaha revoloution
  20. Hasersys
    Hasersys Member
    Sebastian and Tampa Florida / Chicago Il
    Nice, Wish I had the ability to make my frame look that nice. My welder is a cheap pos. I could have used a buddies but I wanted to do mine all my self... Anyway.. I am working on my wiring at the moment also. I think I have figuered mine out. It isn't to hard, you will ENJOY this thing when it is done. Looks 100x cooler than mine!
  21. Cmccully04
    Cmccully04 Member
    State College, PA
    yeah man, that frame turned out pretty sick looking. I also am digging the sporty tank, and the 70's style twisted bars. great looking so far!!!!!
  22. kitman
    kitman New Member
    thanks guys ill give you a little run down of the finished product, so far im not sure on frame color wrinkle finish black or brown, but the tank and fender are getting metal finished(bare metal and clearcoated) i have a buddy who is a CNC machinist so i have brass that i am making spike bolts for some motor/accessory parts. also making brass grips. highway pegs that are brass knuckels and i am recovering the seat with flannel and brass tacks to hold the material and i am making a fork bag to match the seat.
  23. Cmccully04
    Cmccully04 Member
    State College, PA
    this is how I wanted to do my frame, coming straight down the back, but I couldnt figure out what to do with the battery, i couldnt get enough clearence? How are you going to make that work?
  24. kitman
    kitman New Member
    the batterys no problem its a little snug where i put it but i like it, you can also weld it to the swingarm
  25. Cmccully04
    Cmccully04 Member
    State College, PA
    very nice man. thanks for the pics as well. helped me to visualize much better
  26. kitman
    kitman New Member
    finally got my fender in so i went to work on that today got it all mounted up along with the seat.
    [​IMG][​IMG]
  27. Robert
    What did that truing stand ever do to deserve that? Clever use of the arms for the fender brackets... Wish I could just start hacking something like you creative guys. Don't have a creative bone in my body it seems (that or I'm yellow).
  28. kitman
    kitman New Member
    haha what the hell is a truing stand... i made the struts
  29. deadohiosky
    deadohiosky Member
    Columbus, OH
    Nice job man! Diggin the stance, the bars, the tank.
  30. Robert
    I've got a bicycle/small motorcycle wheel truing stand that has uprights with the same dogleg and slots on it. Did you get those out of a BBQ? They look perfect for skewers...
  31. Orange-n-Black
    Memphis Area
    I dig those duct tape pods! :lol: But seriously, what are you going to use?
  32. kitman
    kitman New Member
    i have uni airfilters. i just took them off so i didnt burn them when i was welding
  33. kitman
    kitman New Member
    started the wiring today, i think im on the right track but i am having a problem with the pickup coil i am not getting spark. also i have a main switch and a button starter when i push the button the soilenoid just clicks. im trying to copy the minimum wiring diagram
  34. kitman
    kitman New Member
    when i jump the solenoid it will crank, also im not getting spark AWW.
