How Many Miles Has Your Bike Got On It?
Discussion in 'Hangout Lounge' started by RickCoMatic, Aug 28, 2010.
What's your Mileage at right now?
  1. Below 7,500
    0 vote(s)
    0.0%
  2. 7,500 -to 10,000
    0 vote(s)
    0.0%
  3. 10,000 -to- 12,500
    0 vote(s)
    0.0%
  4. 12,500 -to- 15,000
    0 vote(s)
    0.0%
  5. 15,000 -to- 20,000
    0 vote(s)
    0.0%
  6. 20,000 -to- 25,000
    0 vote(s)
    0.0%
  7. 25,000 -to- 30,000
    0 vote(s)
    0.0%
  8. 30,000 -to- 35,000
    0 vote(s)
    0.0%
  9. 35,000 -to- 45,000
    0 vote(s)
    0.0%
  10. Above 45,000
    0 vote(s)
    0.0%
  1. RickCoMatic
    How many miles have you got on the bike?
    Model.
    Year.
    What, ... (besides Tires, Brakes, Battery, Bulbs ...) needed service, failed, broke, doesn't work, is going?)
    What would you like to see improved?
  2. RickCoMatic
    I'd like to have the 6th Gear which I often try to shift to.
    I love a Gas Gauge?
  3. Polock
    83 seca 750, 40K
    seat cover, 3 exhaust valves, 1 valve spring, clutch, plug wires, steering head bearings, fork seals
    82 maxim 750, 26K
    starter clutch, plug wires, steering head bearings, fork seals
    just for comparison
    85 bmw k100, a lot
    clutch, mass air flow sensor, rear brake rotor, fork seals
    improvements, a few more amps, 1/2 inch more swingarm clearance
  4. andrewlong
    andrewlong Member
    Cumming, GA
    Hello, my name is Andrew, and I've been sober two years.
    I mean....
    22,000 miles
    1992 XJ600 Seca II
    Found out today that the intake valve on cylinder #4 is discreetly scraping the piston! I had a buddy put a fiber optic camera into the spark plug hole, and you can see a half-inch scrape on the piston. I'm HOPING it's something simple like the valve spring. My poor baby -_-
    I would love a gas gauge, too. I don't do well with the count-the-miles-on-the-odometer-thing. Other than that, this bike is a blast.
  5. wizard
    If the bike is running, I would say that is impossible, the pistons do, however, have a valve shaped indent in the top.
  6. andrewlong
    andrewlong Member
    Cumming, GA
    Yea I though the same thing, but the other pistons don't have a scrape mark, and the one that does clicks when the engine is running.
    I'd figure that if any metal object touches the piston while the engine is running, then something has to crack, explode, or turn the universe into a giant black hole.
  7. baytonemus
    baytonemus Member
    Minnesota, USA
    1982 XJ550 Maxim - 39,000
  8. JayEye
    JayEye Member
    Chicago Heights, Il
    1982 XJ750 Seca - 19,500 miles
    Waiting on ignition coils (replacing them both) left 1 & 4 coil went out on me right after a 250 mile trip, I had just pulled in the driveway when she lost her spark of life. :cry:
    Need a pair of good ($250-$350) rear shocks, money a bit tight at the moment.
    Would love to get the computer HEAD warning to go out. I'm using HID xenon bulb.
    After the ridding season is over replace the steering bearnings. That won't be until December if the weather premits (fingers crossed)
    I would like to modify the swing arm so it premits me to use a wider wheel and tire 140mm or 150mm. Don't know if that one will happen.
  9. xjdaver
    xjdaver Member
    Medford, Wisconsin
    82 XJ550R
    19k
    tires, ss brake lines, rebuilt caliper, rebuilt master cylinder, 4/1 exhaust, fuel filter.
    I have a gas guage. Haha.
    A babe sitting on the back would be nice. Does chacal have those?
  10. JayEye
    JayEye Member
    Chicago Heights, Il
    That's part of the reason why I need new rear shocks.... lol
  11. xjdaver
    xjdaver Member
    Medford, Wisconsin
    JayEye: very nice looking Seca tourer. PM me if you wanna ride. Just picked up a Concours I want to put some distance miles on.
    Needing new shocks because of your passenger could really be interpreted the wrong way. Delete your history file.
  12. luvmy40
    luvmy40 Member
    Y-Town, OH
    1981 Seca 750, 38k and change had 19k when I got it.
    Stator was bad when I bought it, coils lasted 2 seasons and the carbs, which performed well until recently need overhauled.
    I added forward controls, drag bars and a wind screen. I also recently switch the Kerker exhaust for a Mac setup strictly due to ease of routine maintenance.
    I too would like to have a wider rear tire and I have a custom saddle being made. A little wider and a little lower than stock.
  13. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    12000 when i got it... and ive only put 1.2 miles in it so far, but then a got a way to go!
  14. schooter
    around 3500
    1982 seca 750
    just needed carbs and brake system cleaned
    more power, chain drive.
  15. xjdaver
    xjdaver Member
    Medford, Wisconsin
    Interesting results so far. I would have expected more of a bell curve. Not a lot of data though.
  16. cutlass79500
    lawrenceville georgia
    my maxim x has 31k runs good no noises or anything
  17. damn
    damn New Member
    USA
    1981 Seca xj750
    38,000 miles
    Replaced battery
    front brake pads and fluid
    spark plugs
    shaft oil
    headlight
    fusebox
    petcock
    rear turn signals
    Still need's
    Headlight relay
    starter relay
    valve job
    carb rehaul
    front fork rehaul
    rear shocks/springs
    Still my daily and fires up within a half sec of pressing the starter button while cold. Runs lean and has vac leaks.
  18. tcoop
    tcoop Active Member
    South Weber, Utah
    About 46000 miles
    Model - 750 midnight maxin
    Year - 83
    What, ... (besides Tires, Brakes, Battery, Bulbs ...) needed service, failed, broke, doesn't work, is going? -
    Cleaned the carbs from sitting for 5 years. After riding it for about 1 year had to split the case to fix the "Stuck in first gear" problem Replace the chain guide and have had no problems sence.
    I too would like a 6th gear...and a windshild, but I can get one of those.
  19. stereomind
    stereomind Active Member
    Tulsa, OK
    '81 XJ750 Seca, AKA XJ750RH
    ~53,700 miles, riding it like I stole it
    Done:
    Oil cooler (by PO)
    Wheel bearings
    Carb bodies (carbs have been completely rebuilt)
    Seat cover
    Fuse box (by PO)
    Engine guards (by PO)
    GP Touring bars
    Handlebar-mounted brake master cylinder
    Intake boots
    LED turn signals and electronic flasher
    Fork seals
    Caliper seals
    Clutch friction plates and springs
    Valve cover gasket
    Fork schrader valve
    Needs:
    New rubber guide bits on both brake calipers
    New swingarm bearings (due?)
    Steering head bearings
    Cam chain (probably soon...)
    New seat foam
    Final gear ratio could be better. Seat could be more comfortable (wider). Other than that, she hasn't let me down yet.
  20. Militant_Buddhist
    Militant_Buddhist Member
    Redmond, WA
    schooter, sounds like what you want is an FJ
    I cleaned the carbs, fiddled with the idle air and syncing, fresh rubber and fluids all around, relocated rear blinkers to accommodate some luggage. Got it with 13k, did valve adjust around 15k. Odometer broke last winter at 16k and have been from Seattle to San Fransisco and back since then.
    What I wish Yamaha had design into my XJ:
    A bar mounted master cylinder instead of the cable op one behind the headlight, linked plumbing for the air adjustable forks for slightly easier filling/setting and even if they leak they are always matched, A lighter weight anti-dive like Kawi did, A lighter weight bike like Honda did.
    As others have said, A little more rubber clearance would be nice. I don't care about running much fatter tires but on a rat tourer like mine it's nice to have the utmost versatility in rubber choice when far from home.
  21. iampnelson
    iampnelson Member
    Sunny California
    Haha, when I bought mine it had ~11k and I put about 20 miles on it that day! Only 1.2 miles sounds like neglect :)
  22. BR549201
    BR549201 Member
    Alma, Michigan
    1983 XJ750 Maxim
    31,+++ miles
    The PO "laid" the bike down one night coming home after drinking..... The bike sat for 6yrs after that.
    Done
    Replace exhaust w/ 4-1
    Replaced bulb in fog light
    Carbs cleaned
    Oil/break fluid changed
    replaced seat
    replaced battery box
    Just picked up a parts bike last weekend
    Needed
    swap blinkers from parts bike
    swap headlight bucket from parts bike
    replace speed/tach gauge cluster
    replace back tire
    would love to have stronger rear shocks
    looking for the famously lost -RIGHT SIDE COVER!!
    Improvements
    6th gear is a GREAT idea
    windshield
    Would love to meet a fellow XJ rider in my area that knows how to work on them....I can swap body type parts...but engine work - not so much.
  23. lowlifexj
    lowlifexj Member
    Grand Haven,MI
    48,000 miles
    valves shimed at 47k
    running like a racebike, been finding the weak drive line parts lately :lol:
    -James
  24. plansea
    plansea Member
    I am at over 50,000 miles on the 650 Seca, my short daily commute to work bike that always starts and runs even when left out in the rain.
    Only spark plugs,oil changes and a front tire for the last 2 1/2 years and 8,000 miles.
  25. jdpesz
    jdpesz Member
    Stanwood, Wa
    81 Maxim 650, 49k miles.
    I have replaced the intake manifold boots, plugs, header studs, brake lines, master cylinder, brake pads front and rear, starter relay. Left side muffler is broken, held together with muffler tape, a pop can, and hose clamps. Tires, battery, air filter as needed. Oil changes on schedule.
  26. formula
    formula New Member
    Lockport IL
    1980 Maxim 650 had 17,000 when I got 3 years ago and just rolled 20,000 yesterday. I replaced the front tire and head gasket in the past 3 years and cleaned the carbs first day I owned it.
  27. SimonRef
    SimonRef Member
    Hull East Yorkshire UK
    When i bought mine milage 92,0000,the P.O. asured me it wasnt genuine,a replacement set he bought!!,camchain changed,Hy-vo chain getting done over winter,otherwise Bulletproof,oh yeah, Starter Brushes down to braids........ quite high mileage methinks. :roll:
  28. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    65,000 :( is there anything i should be worried about replacing? I cleaned the carbs, changed the oil, and bought new plugs..
  29. skills4lou
    skills4lou Member
    Dillon, MT
    '81 XJ750RH
    14K and change
    See sig for repairs/mx, I've only had her since spring 2010.
    6th would be nice, and I need to find some highway pegs to put on.
  30. Sodie82
    Sodie82 New Member
    DePere, WI
    Speakers without a fairing would be awesome although dogs like my singing voice plus new front cross drilled rotor/pads.
  31. KrS14
    KrS14 Active Member
    St Marys, Ontario
    1982 Seca 750 -- 62,000+km
    What I've done:
    Completely drained and cleaned front brake system, new DOT3 in it
    Cleaned all carbs
    Royal Purple 20W-50 with new filter
    Drained and filled with clean 80W final drive oil
    New Plugs
    New Plug caps
    New OEM air filter
    Stuff on the way to me, from Len, to be done asap:
    Valve shims
    Valve cover gasket
    New Valve cover rubber bits all around
    Spin on oil filter adapter + filter
    New clutch handle and associated bits+bolts
    New fork oil seals and dust caps
    New fork drain screws and gaskets
    Stuff to be done over winter:
    New rubber, front and back
    New paint on everything (maybe engine and frame too)
    Fix exhaust holes / Get new exhaust ;)
    New clutch plates and springs
    Steel braided front brake lines
    Possibly new handlebars and MC on the bars
    If the bars happen, new windshield and lose the fairing.
    If the bars happen, I may ditch the atari and get a nice Acewell
    Recover the seat / add / reshape foam.
    LED's EVERYWHERE lol
    LOTS OF CLEANING lol
  32. maximike
    maximike Member
    Portland, OR, USA
    Let's see, over 40,000, hard to be exact as speedo reads low and I replaced the old speedo with one from God-knows-what and just got the odometer close to the old one's reading.
    Things that have gone bad, well, speedometer(cracked plastic gears inside) causing me to replace it and lose trip odometer which didn't fit in housing(maybe from a Seca or Virago?)
    Many leaks from valve cover and head gasket. Um, minor electrical issues, lost headlight for no apparent reason, then it started working again. Only current issue is the self-cancelling signals, but I just found a bad wire under the middle of the cross-bar under the tank that might affect it.
    Some rust and oxidation of various chrome or aluminum bits. Had to re-cover seat. Oh, petcock totally stopped working, replaced that. Re-keyed helmet lock(well, took out a couple tumblers) but that's not the bike's fault, somebody put a bunch of keyed things on this bike that don't match, gas cap looks like screwdriver opened it.
    Other than that petcock issue, it's never had a problem that kept me off the road, I replaced the back brakes, but they didn't need it, nobody ever adjusted the old ones! So that explained why they didn't do anything. Even my Atari works for the most part, had to by-pass that battery thing, but I find the warning handy and annoying when I'm low on fuel(you reset it, then it "sees" gas and turns off, then blinks again, but I don't have the heart to remove it, since it works)
  33. dmccreery05
    dmccreery05 New Member
    Mills River NC
    Around 47,000 speedo quit at 43,000, i will ride it til the wheels fall off, then get new wheels...haha I love my 83 XJ750
  34. kayaker
    kayaker Member
    Appleton, WI
    81 seca 750.
    New exhaust, new battery, new right side cover of course, sync carbs, plugs, plug wires, mirrors, hand grips, clutch lever, oil and filters.
    Not sure how many miles on the bike or what I put on in the past 3 years. Odometer reads 1999.7 and has been stuck there for how long. I like to take it out whenever I can.
    I would like it to be shiny and clean looking like so many I see on this site. However, I would need to invest and work at this and I am too lazy and cheap. And a working speedo and odometer would be nice. But I am happy with it because it runs great and is a blast to drive. I never need to worry about it getting dirty or scratched. I think people dismiss it because it's not pretty. My wife gets lots of looks and comments on her bike (04 Suzuki Savage) because its clean and new looking - I hope they are complimenting her bike and not her.
  35. parts
    parts Member
    prescott valley az
    1985 xj700n
    51,186 miles...original timing chain, clutch, steering and swingarm
    bearings.
    New wheel bearings.
    Stock mirror reshaped to a nice small oval.
    Front seat re-covered by hand.
    Lots of little custom stuff like studs, chrome trim.
    Headlight/t-sig visors.
    New paint with flames on the way as soon as
    I get a compressor for my air brush.
    Chrome trim here and there.
    Clear t-sig lenses-look way better!
    Engine cases and forks polished.
    Hand made leather tank bib, clutch/brake handle wraps.
    Screamin Eagle mufflers-gone as soon as I can find a better
    sounding pipe.
    This bike has been a blast to restore (not to stock of course) and I
    absolutley love the compliments and accolades as this is my first real
    attempt at cutomizing a bike.
  36. TIMEtoRIDE
    Seca 750 (1981) - - 47,000
    came with stainless lines, pods, engine chrome pieces, custom paint, sport fairing, red seat, 4 into 1 Mac.
    I fitted an airbox, shaped and covered a new seat, installed the sport touring stuff, paint and polish (not done).
    http://www.xjbikes.com/Forums/viewtopic ... =ride.html
    Seca 900 (1983) - - 30,000
    came with 20 holes drilled in airbox cover, small turn signals, 4 into 1.
    I fitted a battery, Turbo 650 rear shocks, did NOT clean carbs!!
    My only gripe is the forward leaning position doesn't work on longer trips.
    http://www.xjbikes.com/Forums/viewtopic ... +club.html
  37. Rebel51
    Rebel51 New Member
    Centerville, MN
    I'm at about 22,000, the bike had 19,xxx when I bought it in July. Put a lot more miles on this than I ever did on a Vulcan. But that's probably because I have a gf who likes to ride, so we've been having fun with the Maxim :)
  38. xj650Button
    xj650Button New Member
    Mitchell, SD
    1981 xj650 with 47,000 I have not done a thing to the bike as i have just purchased it.
  39. Newbie
    Newbie New Member
    Gautier, MS
    hmmm bout 28,000ish cant remember the original odometer reading before swithcing it out.
  40. cbrown
    cbrown New Member
    Dorchester, On
    1981 Maxim 550 - 5700km. I only just bought it and have put about 30km myself. Just put new tires so far as the last owner sold it to me with an original 81 rear tire. Runs well, everything is original
  41. theadbrewer
    theadbrewer Member
    Roseville MN
    82 XJ750J 56k miles
    4 front tires
    6 rear tires
    2 clutches
    1 exhaust system
    4 valve jobs
    2 fork seals
    2 tachometers
    4 speedometers
    1 headlight
    1 seat cover
    2 turn signals
    lots of wiring
    4 batteries (first 2 in the first 2 weeks, PO wiring job)
    front and rear brakes
    I think that is it?
  42. frankenbiker
    frankenbiker Member
    gobles michigan
    current engine 46k needs valve job and carb sync.
    82, xj650 Frankenbike
    last engine 69k
    needs new timing chain, so I'm going to rebuild it while its out, for a spare engine for when the current engine gets tired. I figure with the two engines I could keep the bike running indifinatly.
  43. bigfitz52
    let's start with:
    1981 550 Seca: Now at 27,000 miles.
    Got it with 18K miles, a rusty 4-1 Kerker with an open megaphone, congealed front brake fluid, broken signals, ripped up seat, "new" chain per the PO that he never LUBED (ever!) "new" battery that never had its water level checked, front caliper dragging, leaky forks, valves long overdue, carbs never cleaned, mouse nest in airbox, rear brake shoes coming apart-- AND HE WAS RIDING IT!!! (it did have a set of relatively new tires on it.)
    -Replaced exhaust system with stock.
    -cleaned and sync'ed carbs, set float levels.
    -installed inline fuel filter.
    -new fuel line and vacuum line.
    -new air filter.
    -packed intake manifold cracks with black RTV.
    -replaced all broken and corroded turn signals.
    -all new signal bulbs.
    -repaired fuse box.
    -had seat recovered.
    -new front fork seals, and "newer" ff springs from my '83 (7K miles only.)
    -rebuilt caliper, new pads; installed stainless lines, flushed and bled system (M/C ok, miraculously!)
    -front rotor ground and drilled.
    -replaced rear shoes and springs.
    -new Progressive 12-series rear shocks.
    -"Euro" bend handlebar.
    -new handgrips.
    -new clutch cable to go with lower handlebar.
    -all new sidecover grommets and mounting rubbers.
    -adjusted cam chain.
    -new valve cover gasket and donuts.
    -valve adjustment (6 of 8 were tight.)
    -R & I alternator cover to clean, and inspect brushes.
    -replaced poorly repaired clutch cover.
    -straightened rear brake lever.
    -new control levers (ends missing off both.)
    -oil and filter changed regularly now.
    -new spark plugs (every 3000 miles or so.)
    -LOTS of stripping, cleaning, polishing-- it was stored outside for over 4 years by PO, with only a tarp over it during the winter.
    THEN I was able to actually start riding it, which begat;
    -tach drive oil seals replaced.
    -refurbished instrument cluster.
    -installed LED instrument lamps.
    -new speedo cable.
    -R & R speedo drive gearbox to clean/lube.
    -installed Hella H4 halogen headlight upgrade.
    -new chain and sprockets.
    -replaced sidestand switch.
    -replaced starter solenoid.
    -installed clock.
    -replaced battery.
    -clutch rebuilt at 22K miles.
    -installed headlight modulator.
    -new vacuum port caps and clamps.
    -replaced choke cable.
    -currently needs a new rear tire.
    And that was the "easy" bike. The list for the '83 (lower miles, lots of sitting) is nearly twice as long...
  44. zombiehouse
    zombiehouse Member
    Pomona, Ca
    My 1982 XJ550 Seca has around 42K miles on it. I won't even go into all the work that has been done to it in the last 2 months. LOL. If you want to see some of it check this out: http://xjbikes.com/Forums/viewtopic/t=28198.html
    Still a lot to do but she is up and running. :D
  45. Pazalas
    Pazalas Member
    Reading PA
    37,000 and climbing. Brought mine back from the grave also. $300 bike became $2000 project that I love to death!
  46. bhikku
    bhikku Member
    SLC
    16k miles
  47. malibooman
    malibooman Member
    Dryden, Washington.
    15,000 Just broke-in 85 XJ750XN Other than the infamous petcock nothing has failed except me for not taking better care of it. My younger brother brought it new. He passed away in 89. His wife gave the bike to me. I was living in B.C. at the time, but moved back to Washington. Tried to get it through the border legally, what a joke that was. So I just said I going on Vacation and rode down. Haven't been able to get it titled here yet. Just a matter of writing a letter to Washington D.C. Head Office of EPA & ask for a waiver. Because Yamaha did not do a spec for the EPA Canada did not require it. That what the Factory told me when i contacted them. So it has not been rode enough to suit me. Thanks to the U.S Gov for their Bail-out for H.D. who didn't REALLY need it.
  48. wwj750
    wwj750 Member
    central minnesota
    I got my '82 750 Seca in '86 with 1700 miles on it. Had intermittant probs with the speedo & eventually 86ed the Atari altogether. Speedo at that point showed 68K. Used it for the next couple years with no speedo at all, then put one on from a Honda 750. Got another 15k out of it then. So I got at least 85k from the stock motor without a major engine problem. I thought the gears went out, but after some checking its probably just a bent shifter fork. 3 petcocks, 1 starter solenoid & a re-wire of the fuses are the only replacements it needed, aside from general maintenence. The used replacement motor had 20k @ install & runs strong! I guess I'm pretty much sold on these XJ bikes!!!
  49. jazzaero
    jazzaero Member
    Boulder, CO
    My 1982 XJ550 has 4700 miles on it. Just bought it and I love it! Doing some maintenance on it at the moment. Get it ready for me to ride this summer.
  50. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    1982 XJ650RJ 11,110...oops! I forgot about yesterday...make that 11,120 miles
    Battery, Plugs, Oil&filter, Air filter, Fuse block (in the mail), HID headlight, rear brake, front brakes are next on the list
    6th gear would be nice for the expressway, and a front fork cover below the headlight
