Like so many others... suddenly won't start
Discussion in 'XJ Technical Chat' started by Coffee_Monster, Sep 14, 2010.
  1. Coffee_Monster
    Coffee_Monster New Member
    Boston
    I bought my 81 xj650 about 2 months ago and LOVE it. She os my first ride and we've been doing wonders exploring Boston.
    When I got her inspected, they said she was in surprisingly great shape, noted some after market pods, but said everything was in working order. They were right, until yesterday morning.
    I tossed her into neutral, hit the engine switch, engaged the choke, pushed the starter... four tryies to start and it stops. Hit it again, 3 times... and nothing.
    Then, what gets me a bit more concerned, on the third time (supposedly a charm), nothing.
    I whimper (inside of course) go upstairs, read through the manual, go back down and try again... same dilemna. First time, 4 tries, then 3... then it acts dead.
    So after leaving it alone (I did it again this morning, same
    thing), it at least TRIES to turn over... but after three attempts, it goes back unconscious.
    oil seem ok, there IS gas in the tank (I have it on the "res" mark.. center as the manual stated) sparks plugs are beautiful and I believe new (they are FAR too clean not to be)...
    Any ideas? I miss riding her already! :(
  2. Coffee_Monster
    Boston
    After some more reading, I'll give the fuel line / sparks a check
  3. c_muck
    c_muck Member
    Minneapolis, MN
    How much gas is in the tank? Mine wont start once it gets very far under a quarter tank, and then only when it's on PRI. Maybe try starting it with the fuel valve in different positions, from what I understand they get clogged pretty easily.
  4. Coffee_Monster
    Boston
    Oh? I'll give that a shot too!!
    She's almost full now.. maybe 80%.
    Thanks!
  5. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    This sounds quite identical to the problem i'm having... how old is the battery? Is your battery going dead as you try to start? Are your carbs clean? Do you have a fuel filtter?
  6. Cmccully04
    Cmccully04 Member
    State College, PA
    Ditto on the battery, is it fully charged?
  7. Coffee_Monster
    Boston
    Thanks for the thoughts all!
    So far, I Just removed the battery and put her on a charger. The battery was low. The sparks looked fine, but are NOT. Never judge a book by its cover...
    I will let you know tomorrow after I am done doing the small maintenance and seeing how it all goes!
    such a learning experience!
  8. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Ya, these bikes don't like to fire off unless the battery is tip-top.
  9. iwingameover
    iwingameover Active Member
    If they are not new and/or you've ridden the bike with them they should be turning tan/brown around the insulator tip. White is lean. White with silver specks is the beginning of a sad story.
  10. TIMEtoRIDE
    Get a multi-meter.
    Battery should read 12.4 minimum at rest.
    And 9 volts + while cranking.
  11. jmilliken
    Dillsburg, PA
    Iwingameover... what's the white with silver specks?
  12. jeishen
    jeishen Member
    North Port, FL
    its detonation, the silver is pieces of aluminum piston melting into the insulator.
  13. iwingameover
    Correct. Obviously not good.
  14. koolaid5
    koolaid5 Member
    Chambersburg, PA
    did you ever get this figured out? Today mine decided to just do nothing when I attempted to start it up. It turns over if I jump the starter solenoid though. Not sure why the starter button is not working all of a sudden, but I want it fixed, so I can take it for a test ride.
  15. 82maximXJ650Bobber
    82maximXJ650Bobber Member
    New Hampshire
    Mine does the same thing from time to time. I'm thinking of replacing the 2 yr old battery as the solenoid is new last year, if nothing improves, cleaning the contacts on the ignition switch.
  16. koolaid5
    koolaid5 Member
    Chambersburg, PA
    I took my start switch apart last night and the contacts just weren't making good connection. I slightly bent the on and now it works great :D
