1978 XS400
Discussion in 'XJ Technical Chat' started by djg42, Sep 16, 2010.
  1. djg42
    djg42 Member
    Hello,
    can anyone give some help witth my xs400? I just bought one, not running.
    I soaked the carbs and re-asembled, the bike came with no fuel lines-
    anyone know what size?
    Also, the petcock has two valves-anyone know what size fuel line i need? Thanks!
  2. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    Ahh the SOHC 400, closer to the XS650 than the XJ's
    Petcock is vacuum activated, larger line will go to the carb the smaller needs a vacuum hose to connect to a barb on the cab boot...
    Not sure if the diameter, but someone will chime in.....
  3. kirkn
    kirkn Member
    Orlando, FL
    Hmmm..... measure the petcock outlet or carb inlet. It'll either be 3/16, 1/4 or 5/16.
    Or, go to Ace Hardware and buy 18" of each size for about $2 each. Use whichever one fits the best...
