Fixing a carb part
Discussion in 'XJ Technical Chat' started by jeffh2345, Oct 13, 2010.
  1. jeffh2345
    jeffh2345 Member
    Hampton, VA
    While cleaning my carbs, I popped off a float tower. Was a clean break right where the tower comes out of the body. Some Gorilla Glue super glue has it back in place, and seems to be very strong. I thought about using JBWeld, but have had experiences where JBWeld let go.
    Ok, so here's my question...The very top of the tower is only in contact with gas when bouncing around, so it's not like it's soaking in it. What I was thinking is the Goriila Glue Super glue, and then cover the entire joint with solder...would seal it off and add a little strength. Any thoughts as to why that wouldn't work? Not like it's holding any real weight, just some vibration and the occasional bump.
  2. Lou627
    Lou627 Member
    Queens, NY
  3. waldo
    waldo Member
    San Jose, Ca. 95125
    The Glue will contaminate the solder so it probably will melt doubt you will get the solder to stick. The gas actually creeps up the metal inside the carb bowl so it does get on that part even when its sitting still best repair is a weld nothing else can really be counted on to hold . Tried the JB Weld myself one time it lasted for a short time good luck.
  4. jeffh2345
    jeffh2345 Member
    Hampton, VA
    You're right...the solder wouldn't stick no matter what I did. BUT, I did some reading on the Gorilla Glue Super Glue, and it is supposed to be "gas-proof". So far it's held for a couple of days with the bowls filled. We'll see. was also thinking about the super glue...then a very light coating of a gasket material made for gas.
  5. schmuckaholic
    California
    I remember seeing a pic in a thread, which I don't think was even about the float pillars, but whoever it was had dovetailed the pillar into the carb body.
  6. zap2504
    zap2504 Member
    Middletown, PA
    There's a guy in "Other Motorcycles" who broke off a float mount for a XS400 and fastened it back on with gas tank repair epoxy. So far so good. Subscribe to his thread to see the long-term effectiveness.
  7. RickCoMatic
    You should look for a Used Carb Body and swap all your parts over to the replacement.
    Look at the LINK I posted on the other Post.
    Having it LASER Welded will Fix it for good.
  8. theadbrewer
    theadbrewer Member
    Roseville MN
    I have been living with this for years. PO broke it I found it and have been JB welding it every year since. A new carb body is the answer but who has the time for that. I have problems with running rich on that cylinder all the time. Going to fix one day.
  9. RickCoMatic
    Some jobs you should do; but can't find time for require "Special tactics".
    One Special Tactic is: Pulling an All-nighter.
    I've done some of my very best work, very late at night ... under No Loud Noise regulations.
    You can get an awful-lot done when you're burning the Midnight Oil.
  10. snowwy66
    snowwy66 Member
    Salt Lake City, Utah
    burning the midnight oil on my suzi involved the wee morning hours.
    LOL.
    5 minute jobs on that thing are more like 5 hours.
  11. Robert
    Ha ha ha ha... I'm chuckling 'cause I am a lifetime member of the midnight oil club. Funny how you seem to be able to focus without the day's distractions. Glad to know I'm in good company.
