WTB - tachometer or instr. cluster for 550, 650, 750 Maxim
Discussion in 'For Sale, Trade/Swap, Wanted' started by baytonemus, Oct 5, 2010.
  1. baytonemus
    baytonemus Member
    Minnesota, USA
    I've got an '82 550 Maxim, but I believe that the instrument clusters are about the same for these bikes...
    - XJ550 Maxim
    - XJ650 Maxim and Midnight Maxim
    - 1983 XJ750 Maxim and Midnight Maxim
    I need a tach but would consider buying a complete instrument cluster if the price was right. Send me a PM with details. Thanks!
  2. iwingameover
    iwingameover Active Member
    81 650 maxim's are mechanical. You need a mechanical or an electric?
  3. baytonemus
    baytonemus Member
    Minnesota, USA
    Mine is mechanical. Round dial speedo and tach gauges with the four square warning lights in the middle.
  4. bigfitz52
    The 550 Max's tach is mechanical, the guts are similar to the other mechanical tachs but the face has the bottom 1/4 or so lopped off flat.
    Baytonemus read my response to your other post on the subject.
    A lot of the 750s have electronic tachs.
  5. baytonemus
    baytonemus Member
    Minnesota, USA
    Re: WTB - tachometer or instr. cluster for 550, 650, 750 Max
    Here's a pic of one up for auction on eBay.
  6. chacal
    All XJ550 Maxim tachs are mechanical, as are the 1980-81 XJ650 Maxim and Midnight Maxim models, and all are a direct bolt-in replacement for yours (Note: different style light bulbs were used in the '82-up clusters).
    1982-83 XJ650 Maxim and 1983 XJ750 Maxim models used an electrically-driven tach, but the body is the same and it will fit into your cluster/housing exactly.
    We offer a "conversion harness" that allows you to use the factory '82-3 electric tach in place of the mechanical tach, it's plug-and-play, no cutting or splicing needed, can revert back to the stock system in about 30 seconds. Comes with a block-off cap for the cylinder head mecahnical tach drive housing, too.....
  7. iwingameover
    I should have a set at the shop. It'll probably be tomorrow before I get over there to verify. Do you want just the tach or the whole thing?
  8. baytonemus
    baytonemus Member
    Minnesota, USA
    I just sent you a PM, although I'm not sure that messaging is working for me right now. The message I sent didn't display in my "Sentbox."
  9. iwingameover
    Got it and responded. It should stay in your outbox until I read it then it goes to sent.
  10. Robert
    I've got a set of 550 gauges in poor shape but rebuildable if you are interested.
  11. baytonemus
    baytonemus Member
    Minnesota, USA
    Thanks for the offer, Robert. I've got a couple of things brewing right now but will let you know later if I'm still looking.
  12. Natan
    Natan Member
    Middleton, WI.
    I have a few of them if you are still looking for it. Please let me know.
    Natan
  13. SovereignDragon
    SovereignDragon Member
    Leavenworth, KS
    Don't know if you are still looking but i've got two. one is chrome from a 1980 xj650 and the other is black from a midnight maxim (1980 xj650)
  14. baytonemus
    baytonemus Member
    Minnesota, USA
    I found a nice one for $40. Thanks for the message, though. It was a good reminder that I needed to post this to say I'm not longer looking.
