Bare min desired radio "watts" for behind a Windjammer
Discussion in 'Hangout Lounge' started by Metal_Bob, Nov 22, 2010.
  1. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    Someone mentioned it in a post I was commenting in, but I can't find it.
    How many minimum desired watts would you want to install in a Cycle Sound radio shell for a Windjammer radio?
    "Claimed" watts obviously.
    Mostly for slower speed use, but might be nice to hear some of the tunes at 65mph with a helmet on.
    It doesn't have to blow me away, but it would be nice to hear at speed... (Yes I realize it may not be legal everywhere).
    I want to order a marine radio in the next few days. But I'm not sure if I'll need an AMP as well to be able to hear the radio.
    Initial Use: Want to play Christmas music during the Marine's Toys for Tots ride in Chicago on Dec 5th. So I'm short on time but if I order this week I should have enough time unless it pours the next 2 weeks. (It just might in Chicagoland).
  2. BillB
    BillB Active Member
    Tulsa Oklahoma
    I bought chinese equipment for this and it sucked.
    I had 200 watt amp and speakers. I could fart louder.
    Id say anything over 100 watts would be perfect if you are using quality equipment.
  3. Metal_Bob
    Bourbonnais, IL
    Well my budget at the moment is minimal and currently planning on a basic Shaft model and plan on upgrading later.
    http://www.amazon.com/gp/product/B002E9 ... PDKIKX0DER
    I know it is cheap and basic, but it will take zero modification to install (cycle sound housing was made for shaft radios in 70/80s).
    I might be able to afford an amp now and get a better radio in the spring.
    EDIT: Though a bit more and NOT a two shaft receiver, this is the "full" package (maybe minus wiring) I am looking at on Ebay.
    http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... K:MEWAX:IT
    If I just upgrade and get an amp for the above radio later I'd be saving some money.
    Yes I'm sure its a generic brand, but I can't afford 300-400 bucks for just the head unit. :(
  4. malibooman
    malibooman Member
    Dryden, Washington.
  5. wamaxim
    wamaxim Active Member
    Vancouver, USA
    Take a look at this one. Plenty of sound without aux amp and it is waterproof! And reasonably priced at less than $150. I think there is a newer model of the same radio available.
    Jensen MSR2007 marine audio system
    Loren
  6. mlew
    Stay away from cheap radios like Pyle and others. The price may be good but you would do better getting a radio from a junk yard. I have learned the hard way, sitck with name brands electronics.
  7. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I've had several of those Vetter radio housings with cheap car radios in them. Just a name brand (Panisonic, Pioneer Or even Kraco) will work just fine. The later model AM/FM recievers have more watt output nowadays, so you'll be in good shape with one of them. I first check out the local pawn shops and get some great deals there compared to going brand new.
    The best bet is to find a good pair of 4" speakers, which make all the difference in the world. I used Pioneer speakers in my last fairing and they sounded great compared to the factory speakers that came with the Vetter housing.
    I still have two Vetter radio housings for sale if anyone needs one. They seem to be getting rare. PD
  8. Robert
    I ran a Pioneer 25x25 watt unit with Pioneer speakers in my Vetter radio pod with no problems. Plenty loud.
  9. PainterD
    The Vetter faring has a nice way of capturing most of the sound from the radio and preventing much road/wind noise you get without it on. In most cases just a cheap radio is all that's needed with the fairing. My last one had a $30 Kraco unit installed in it and it sounded plenty good.
    I just installed a Harley batwing style fairing on my Honda Shadow, with a 250 watt amp wired to 5-1/4" speakers and talk about overkill!! It sounds better than my car radio and has volume to spare. I use my MP3 player for FM radio and recorded tracks that I like.
    There are alot of after market radios that have an MP3 plug in them, so you can also llisten to MP3 music if there aren't any good/strong stations in the area. Just a thought. PD
