Locked gas cap, no key
Discussion in 'For Sale, Trade/Swap, Wanted' started by jamcam1999, Nov 24, 2010.
  1. jamcam1999
    jamcam1999 Member
    <a href="http://maps.google.com/maps?q=50.064192+-
    How do I get the gas cap open on a yamaha seca fuel tank when I have no key for that particular lock? Thanks, Jack
  2. hogfiddles
    Use a 7/16" drill bit, drill the core out. Drill down about 3/4" or so, then use a good sized screwdriver to turn the core. Then you'll need to get a replacement assembly for the cap, or get another cap w/ good key.
    Dave
  3. Artie(RT)
    Artie(RT) Member
    Raleigh, North Carolina, USA
    Or,
    For a less destructive option, you could try a locksmith. I was surprised one time when they were able to identify a motorcycle key I had, knew the blank that was needed, and could easily make a duplicate.
  4. clipperskipper
    clipperskipper Member
    Cape Cod, MA
    They're fairly low-tech locking mechanisms, try a small scratch awl in
    order to press the tumblers into place, then a small blade to rotate the cylinder.
