Just a question
Discussion in 'Hangout Lounge' started by Igor, Dec 11, 2010.
  1. Igor
    Igor Member
    Santiago CHILE
    Hy everybody, I think that I´m running to rich in gas, now the quetion, how do I reverse that matter??
    Thanks from this end of the world
  2. wizard
    How do you know? by looking at the plugs? first set the floats to give the correct fuel levels, before tinkering with the pilot mixture screws.
  3. Igor
    Igor Member
    Santiago CHILE
    Thanks, and how do I know the correct fuel level??? I believe that the float are in the original position, never been move
  4. wizard
    Connect a clear plastic tube to the drain / s & loosen the drain screw / s, the fuel should level off a couple of mill' below the gasket line.
  5. Igor
    Igor Member
    Santiago CHILE
    OK but how do you adjust the floats?? another thing , I´m running with 125 jets, are the rigth jets??
  6. bigfitz52
    Igor; You have "pod" filters on the bike, don't you? It's impossible to tell you exactly what the "right" jets are because the stock jets are most likely not "right" any longer. Let's attend to other things before any re-jetting.
    You adjust the floats by JUST BARELY TWEAKING the little "tang" on the float that operates the needle valve.
    The best thing to do is as in Wiz's picture, take the rack off the bike and get it good and level; then check each carb as illustrated. The fuel level should be from 1mm to 3mm below the edge of the carb body, as indicated by the little blue lines in Wiz's pic.
    If any need to be adjusted, then you remove the float bowl and carefully adjust. Start by checking the floats; if you have one that is not shuttiing off at all, this process will reveal that as well.
  7. Igor
    Igor Member
    Santiago CHILE
    Thanks my friend, and I do have filter box, not pod filters, I will do wath you say and i let you know, for now my spark plugs are coming out too black , other thing I´m using D 8 EA spark plugs should I use DR 8 EA??? or what do you recomend??
  8. grinder
    grinder Member
    norfolk,uk
    d8 and dr8 are virtually the same plug dude.the r just means it has a resister in it.this stops the spark plugs interfering with tv signals etc.
  9. Igor
    Igor Member
    Santiago CHILE
    That is all that the R means and why should I care about the TV interference??
  10. grinder
    grinder Member
    norfolk,uk
    yes,its all it means.its not all it interferes with,but it makes no differance to you when you are riding.someone once told me plugs without resistors will break down easier than thos with,but i couldnt say that is true or not.if i am buying,i buy with.but thats just because i think i am getting more for my money.
  11. TIMEtoRIDE
    If you have resistors in the caps you don't also need resistors in the plugs.
    Hey - how about a nice, fat spark generator to mess up everyone's cell phone and radio so they pay attention to "that motorcycle" !!
  12. Orange-n-Black
    Memphis Area
    Great idea, I saw a cop talking on his phone this morning as he passed me!
  13. Igor
    Igor Member
    Santiago CHILE
    So in one word, it don´t make a diference to the bike the R???
  14. wizard
    Yeh, the 'R' weakens the spark, but it is longer.
  15. Igor
    Igor Member
    Santiago CHILE
    Hy Wizard, what about my question of he jet size , now I´m running with 125 size , are the right ones for my bike. AAhh it´has 140 before but I was toll they where much too big.
  16. bigfitz52
    Igor; You'll need to check a manual; unless one of the other XJ400-4 owners can chime in.
    Didn't you reinstall an airbox? That will affect the answers to the jetting questions.
    D8EA's should be correct; your bike has resistor caps.
  17. Igor
    Igor Member
    Santiago CHILE
    Ye my friend, I do have a filter box in my bike
  18. wizard
    Igor I think the mains should be 135, but not absolutely sure.
  19. Igor
    Igor Member
    Santiago CHILE
