Wheel bearing question for the experts
Discussion in 'Other Motorcycles' started by gitbox, Dec 14, 2010.
  1. gitbox
    gitbox Member
    For the sake of this forum, let's say this is about an XJ. I'm sure it applies to many bikes anyway.
    On bike wheels that have a machined shoulder on one side of the wheel for a bearing to seat and no shoulder on the other side with a spacer in between, how does one seat the non shouldered bearing so that there is no side load? Too tight against the spacer and there is a constant load from the center outward, too loose and there is a constant load inward toward the center when the axle is tightened up. How does one get it just right?
  2. Rice_Burnarr
    Rice_Burnarr Member
    Near Philadelphia, PA
    I'm no bearing expert, but it seems nobody else wants to play. :lol:
    One side at a time...
    So this machined surface on one side of the wheel... It contacts just the outer race of the bearing on that of the wheel? You press the bearing into that side of the wheel and this machined surface establishes the depth of the bearing into the wheel on that side, right?
    Tough to do without pics or sketches, and I've got to admit that I've never had the pleasure of messing with the bearings on my bike!
  3. waldo
    waldo Member
    San Jose, Ca. 95125
    Thats just not right what bike are you working on
  4. MiCarl
    My thoughts too, that's why I haven't piped in sooner.
    I don't think I've ever been into one that didn't have a shoulder on both sides to locate the bearing race.
  5. ST0CKM0NK3Y
    ST0CKM0NK3Y Member
    Berkely Michigan
    Are you sure you have the right bearings? All the ones ive seen are nothing like that.
  6. gitbox
    gitbox Member
    All right! I got some responses. I guess I need to clarify.
    The bearings in question are the front wheel bearings on my Kaw. See pic below. One side of the wheel has a shoulder for the bearing outer race to seat against (upper 601). The other side does not. There is a steel spacer tube (92027) that fits between the bearings that sets up the seating depth for the bearing on the unshouldered side (lower 601). The problem is that the process of seating that bearing presses it against the spacer causing it to have constant outward pressure on the inner races and if it isn't seated enough, there is inward pressure when the axle is tightened. How do I seat it so that there is minimal or no side pressure?
  7. waldo
    waldo Member
    San Jose, Ca. 95125
    92033 and 92033A are clips that keep bearing from coming out of the wheel?
  8. Robert
    Moving thread... (NOT XJ related but interesting just the same).
  9. bigfitz52
    "lower" #601 should be able to move slightly laterally within the wheel so that it seeks its own final position when the axle nut is tightened, shouldn't it?
  10. gitbox
    gitbox Member
    Hey Fitz. Yes, you would think so but it's a press fit just like the other side.
    I got hold of a 30 year motorcycle mechanic and he told me the bearing on the shoulder free side needs to be driven in so that it just touches the spacer - not hard against it and not so far away that the spacer is loose. He said it's an acquired feel. It must be positioned so that both inner races touch the spacer and yet still can turn. If it isn't just right, the bearing life is shortened. Tricky, to say the least.
  11. Orange-n-Black
    Memphis Area
    When pressing in bearings, its important to support the outer and inner races equally. First press in the (shoulder) side bearing. Flip wheel over with something flat against the bearing (across both races)for support, insert spacer, press other bearing the same way slowly till it seats. As long as both races are supported equally they will be in plane with each other and not lead to premature failure.
  12. Rice_Burnarr
    Rice_Burnarr Member
    Wow. That design obviously works, but... it's really cheezy.
    The bottom of the counterbored recess establishes not only mounting depth, but it also establishes alignment of the outer race parallel to the direction of wheel rotation. Without that shoulder, even if it's a press fit, you run the risk of having the outer race be in misalignment. Cocked in the bore a little if you will.
    Also, you're trusting a press fit, and only a press fit, to retain that outer race where you want it. Forever. No matter what bumps you hit? No matter what temperature changes it see? No matter hot far you lean over in a turn... Forever?.
    I smell bean counter influence...
    The input from your 30 mechanic is good advice, but there's more to it than that. What you REALLY want is for the balls to be centered in all the race grooves when the alxe is tightened up. Even if you press against both the inner and outer races when you insert the second bearing, you run the risk of having the balls slapped all the way to the outside edges of the groove in the outer race (and obviously the inner edges of the inner races.)
    I bet that if you insert it too tight and then go for a short ride, the balls will heat up, expand, and push that semi-floating outer race back a bit. Might start out tight, but would end up with some slack once cooled. Haha!! Might cook the bearings in the process, but alignment will be achieved!
  13. waldo
    waldo Member
    San Jose, Ca. 95125
    Actually the clips would keep the wheel from walking off the bearing so insert the bearing on the non shouldered side just enough to get the clip in. At least thats what it looks like to me
  14. gitbox
    gitbox Member
    Thanks, guys. To your points:
    Orange and Waldo: Agreed.
    Rice:
    Maybe, but they didn't change it for 20 years.
    Agreed, although I can't see how the bearing can be cocked much when the outer race is in full contact with the bore. At least not cocked any more than the play built into the bearing itself.
    The snap rings will keep them from going too far.
    I'm not sure if that design is really any cheaper. It still has to be precision bored with a snap ring groove cut. The only difference being that it's not bored to a particular depth.
    Right. That was his point. Having no side load on the bearings when all is torqued up.
    That is a good point - and maybe the reason for the design - allowing the bearing to "find its happy place".
    Excellent feedback! I never thought installing wheel bearings would churn up the gray matter so much.
  15. Rice_Burnarr
    Rice_Burnarr Member
    Yeah, I don't mean to give the impression that I expect the bearing to come flying out. My point is that I just don't see the advantage of not simply counterboring both sides like other applications. You're right about the cost. Can't be much different and it sure makes assembly more finicky!
    Maybe they didn't think they could hold the length accuracy on the spacer between the two inner races? :?:
    Two precision depth counterbores vs. one side counterbored and the other side bored through.... All with snap ring grooves.
    So when you put this thing together and tweak the preload so you've got the balls centered in the races, is there a (intentional) gap between the snap ring and the semi-floating outer race?
  16. gitbox
    gitbox Member
    Sounds like you've done some metal machining.
    I originally seated the bearing too tight so I had to fab a tool in order to tap it back out a bit from the other side. The way I have it set now is with no gaps. The inner races just touch the spacer so they can still be turned, whereas before I had them so tight I couldn't turn them. It makes me wonder how they do it at the factory. I have the Kawasaki service manual but it doesn't go into any detail.
    Now if I can just get used to handling sub freezing metal, I think I could finish this project.
  17. Rice_Burnarr
    Rice_Burnarr Member
    Yes, I do some metal machining. Doesn't pay the bills, but it keeps me out of trouble (for the most part). :lol:
    So what's your take on the "why"? Ease of machinability? Alignment accuracy? Tolerance stack-up? Sure as heck sounds like it's not "for ease of assembly"!!
    Whatever the reason, it was good enough for them to keep it like that for 30 years, right?
    Out of curiosity... Do you know what happens if you press in the semi-floating side first. A little past the snap ring groove. Put in that side's snap ring and then (from the counterbored side) press the first side back out a little until it's snug against the snap-ring. Then put in your spacer tube and press the second bearing into the counterbore. Is everything too loose then?
    PS - Haha!! Don't let the bearing purists hear how tapped that bearing back out and re-used it...
  18. Orange-n-Black
    Memphis Area
    Some engine bearings don't have a shoulder,snap ring or bearing retainer to hold them in place. The only thing that holds the bearing in place is the press fit. If a bearing moves its because of wear in the bore. In the case of the rim the bearings not going to move in because of the steel bushing and its not going to move out because of the retainer ring. I know it seems to be better to have a shoulder on each side, but if you've ever had to remove a destroyed bearing before,you would be thankful for not having a shoulder on each side. As far as cocking the bearing goes, that will always cause a problem to bearing and bore. So its important to make sure its straight to start with and then press, you can think about it but don't use the hammer. :lol:
  19. gitbox
    gitbox Member
    Rice, I made that special tool so I could tap the outer race, not the inner one, so the bearing should be fine. It didn't take much to get it just right. I think I was pretty close already. Good idea about the assembly procedure. I might try that on the rear - it's the same design. I might email their training facility ask them why. If I studied mechanical engineering instead of electrical, I might know the answer.
    Orange, the Kawasaki manual describes cocking the spacer slightly so the inner race can contacted with a long drift and a hammer to drive it out. Then the spacer is removed and the shouldered bearing is driven out the same way. Installation is with a special tool (looks like a large socket so it only contacts the outer race) and a hammer. With the wheel hub heated and the bearings from the freezer (my garage), they tap in pretty easy.
    PS: Rice, I took a metal machining course at the local college just because I always had an interest in it. I learned a LOT and it was great fun.
  20. Rice_Burnarr
    Rice_Burnarr Member
    I know it's academic at this point, but I wish I knew what the advantage is... If I knew why, maybe I could use it in the future in some application. It's those curious little tips and tricks that can really become valuable once you understand the reasoning.
    I'm an EE too. Probably should have been an ME but could never have made it through the thermo and fluid flow classes without going insane!! 8O
    Hey Orange-n-Black, do you have any theories as to the why Kawasaki would make it this way instead of two counterbores?
  21. Orange-n-Black
    Memphis Area
    The shoulder is only there to insure that the whole bearing (assembly) is positioned in the right space of the hub. The bearing aren't going anywhere with a shoulder and retaining ring on one side and the spacer in the middle followed by the other bearing and retainer. So a shoulder isn't needed on each side. A lot of rotors are like this on cars.
    My thinking on this is they do it this way to make it easier to remove the old bearings. If you remove the axle and the inner race and little balls fall out, that means a hammer and punch to peck around the outer race to remove it. A lot easier to do without a shoulder in the way. :x
  22. Rice_Burnarr
    Rice_Burnarr Member
    I get what you're saying now! Before when you were talking about removing a destroyed bearing, I was thinking "So what? You just press it out like any other bad bearing.", but I wasn't thinking of one that had failed so catastrophically that the inner race had come completely loose from the rest of the assy.
    You're right... If the inner race falls out on the floor and the counterbore ledge completely occludes the outer race leaving you nothing to press against to remove it, I'd be bitchin' up a storm!!
    But... That still doesn't help you if the conterbored side is the one that falls apart, right? :lol:
  23. gitbox
    gitbox Member
    The wide range of wheel bearing life mentioned on the Concours site is likely related to the tricky installation of these things. Some only get 20k and others double or triple that. It's funny how some "no brainer" tasks can get pretty complicated when you start into it.
  24. Orange-n-Black
    Memphis Area
    Rice_Burnarr said
    But... That still doesn't help you if the conterbored side is the one that falls apart, right? Laughing
    The best way to get these out is to use a file bit in your drill. File the race about 3/4 thru, then take a hammer and chisel to it without damaging the bore. But if that isn't possible you'll just have to use a hammer and punch the best you can (with a lot of time and patience) from the other side. :wink:
  25. Rice_Burnarr
    Rice_Burnarr Member
    That's cool, and I bet you're right. I bet the folks that are getting highest mileage are most likely the ones who are getting the bearing pressed in to jusssst the right spot, and the people who are burning them up early are pressing them in too far.
    So... You're the expert now, right? You gonna offer up your services on the concours site? :D Have you talked over there about your findings?
    Orange-n-Black, I've run into similar situations with bearings in the past and I've got two methods for getting the outer races out of the counterbored side:
    First thing I would try is put bearing back together as best you can and then you can push on the inner race to force the outer race out. What I mean by that is to put the inner race back in and stuff as many balls back in as possible (Once the retainer cage is removed, it's likely that you can get ALL the balls back in place.). Use grease to hold them there, and then you can spread the balls out a little and they'll hold the inner race in place. If the inner race or the balls have turned to dust, you can scavange parts from the other side bearing. Once the bearing is put "back together" then just press it out like you would normally do.
    If that doesn't work, I would cut the outer race as you suggested, but I would use a cutting disk on a Dremel. Less hardened material to remove than if you would use a burr in a drill.
  26. Orange-n-Black
    Memphis Area
    That'll work too.
  27. gitbox
    gitbox Member
    Expert? Hah! Long way from that.
    There was a discussion over on the Concours site on this subject but once I posted what the mechanic told me, the thread died. I found that funny too because they will usually grind a subject into a fine powder. Heck, they'll go into nodal analysis and Bode plots for the temp gauge circuit. (thought you might like that). Anyway, they're good guys and very helpful. Just like here.
  28. waldo
    waldo Member
    San Jose, Ca. 95125
    Gitbox I think your avatar is a picture of me thats how I learned about electricity the first time. Second time was an alarm clock radio I wanted to see how the numbers changed I think I was in the third grade . Later it was a lawn mower spark plug then the dryer, heck I remember when they came out with HEI ignition on the Buick La saber no more pulling a plug wire off to test the effect on a cylinder I think I was 12 then. Memories
  29. Rice_Burnarr
    Rice_Burnarr Member
    Sweet!! I'll have to stop over there sometime!! (I'm a theory guy. Haha! Betch'a didn't know that already? :) )
    It does seem odd that the thread would have died like that. I've got the same problem too. Don't know why, but I sometimes feel like "The Thread Killer". Not this one, but sometimes...
    Yeah, I like your avatar too. Reminds me of a buddy of mine who grew up in New York City. One day as a kid in the sixties, he was messing around sticking something in an outlet, got a big spark, and all the power went out. Biggest blackout the east coast has ever seen. Of course, it was probably complete coincidence, but for years, his parents had him thinking that he caused the whole thing!!
    "NOW look what you did!!" :lol: He's now an EE as well...
    PS - Didn't I see your avatar over at the PM forum as well, or am I getting you confused with someone else?
  30. gitbox
    gitbox Member
    PM forum? Not sure what that is. On the Concours site I use the same handle but someone complained that I copied their old avatar so I changed it. I don't even remember where I came across that pic. It looks like me when I was that age and like something I would do. Glad I didn't, though - plenty of jolts came later. Goofballs in class labs would charge up electrolytic caps with a 400v power supply and toss them to you. That'll wake you up!
  31. Rice_Burnarr
    Rice_Burnarr Member
    Haha. I remember the ole' capacitor battles as well!! Good times... Good times... 8)
    So, when will you know if your wheel bearing teqnique was successful? Have you gone back into the cold to try the assy or are you waiting for warmer weather?
  32. gitbox
    gitbox Member
    Yep, got the front end all back together and feeling great! Just gotta put the plastic back on. I thought the old bearings were in pretty good shape until I felt the new ones. Much snugger.
    And what was the PM forum?
  33. Rice_Burnarr
    Rice_Burnarr Member
    Excellent. Still wondering why Kawi did it that way, but in any event, glad to hear that the work was successful. I'm gonna send all my Kawasaki work you way in the future.
    PM is Practical Machinist. It's an excellent forum for all things machining, etc. I've learned an enormous amount from lurking over there and reading, and reading, and reading. I don't remember the member's name or handle, but one of the people over there mentioned this forum a few years ago, and I came here to take a look. Been here since. :)
    I was thinking that you might have been the guy over there that turned me on to XJ (with your metalworking interest and all...).
