XJ 550 Triple backbone mod
Discussion in 'XJ Modifications' started by Zealousrocker, Dec 18, 2010.
  1. Zealousrocker
    Zealousrocker New Member
    Has anyone done a mod to the xj550 triple backbone section of the frame?
  2. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    What did you have in mind?
  3. 16ozbud
    16ozbud Member
    louisiana
    I have. I turned mine into a rigid. Extended center tube all the way past seat mount and cut the two smaller outside ones off right past coil mount. Tied the two to the center tube with a piece of flat bar. Was able to fit a peanut tank on it then.
