XJ650 tank vs XJ750 tank
Discussion in 'XJ Technical Chat' started by jasonm, Jun 26, 2009.
  1. jasonm
    jasonm Member
    Mt Pleasant Iowa
    How much more fuel does a 750 tank hold over the 650 tank?
  2. SQLGuy
    SQLGuy Well-Known Member
    About a gallon
  3. jasonm
    jasonm Member
    Mt Pleasant Iowa
    Ok thx
  4. pictishusa
    pictishusa Member
    West Richland, WA
    on my 650 tank i cruised about a hundred miles then filled up, i switched to the 750 tank and i cruise about 130 before i fill up, ive never hit the reserve in the tank so i dont know actually how far i can go, my bikes milage seems to jump around quite a bit from 41 mpg to about 49 mpg.
  5. minturn
    minturn Member
    colorado
    Sorry to divert your thread, but it looks like your question has been answered. So here it goes.
    What model/year 750 tanks will fit a 80 XJ650?
    Thanks.
    Jim
  6. stereomind
    stereomind Active Member
    Tulsa, OK
    a 750 Seca tank will fit nicely on the 650 mounts, but it will not match the seat and the sidecovers without modifying the seat and cutting on the tank a bit. This is exactly what I'm going to do with my 650 project.
  7. Deadulus
    Deadulus Member
    Dufur, Oregon
    I have an 82 750 on my 80 650 Maxim
  8. Altus
    Altus Active Member
    London, Ontario
    To be more specific, the 750 tank holds exactly 6 litres more fuel than the 650's -- 19 vs 13 -- with a 3 litre reserve on both.
    Any 750 Maxim tank will fit your Maxim - be aware that they have a fuel sender unit in them, so you can either figure out a fuel gauge, or just leave it unused.
  9. hogfiddles
    An XJ750 MAXIM tank will interchange directly with an XJ650 MAXIM tank. Direct bolt up, no mods at all. Mileage increase--- i would go to reserve at about 90 mi and gas up between 100 and 105. I installed a 750 tank on my 650 about three years ago. Now I got to reserve around 130-140, and can go to 150 before fueling. I have gone as far as 179 mi, but that's when I ran out of gas (only 4 mi from home on a long return trip, too......figures) But, if I go to 150, I better find a gas station quick, cuz I don't want to push my luck past 155 which I have been able to reach.
    Dave Fox
  10. mpato640
    mpato640 New Member
    what about the other way around, does a 650 tank work on a 750?
  11. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Yes, I have a 650 Maxim tank on my 750 Seca build and it was a perfect fit with no modifications. Of course the seat and side covers will not fit perfect, but mine was a bobber project, so I was making sidecovers and a seat to fit anyways.
    Here's what it looks like:
  12. mpato640
    mpato640 New Member
    ya mine is too so it should be all good, thanks
