finding front brake pads....
Discussion in 'XJ Technical Chat' started by tonymyrs, Jan 31, 2007.
  1. tonymyrs
    tonymyrs Member
    portland, Or
    Can anyone lead me the way to a web-site where I can find some good front brake pads. I think mine are just about done there sqealing pretty bad.
  2. bosozoku
    bosozoku Member
    Albany, Oregon
    Noise isn't necessarily an indicator of pad wear. You may only have glazed pads.
    There is a small cover on the back of each of your calipers to peek through and aee how much pad material is actually left.
    If you do need pads, EBC is a good choice.
    http://www.ebcbrakes.com/catalogues.html
  3. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    I don't know about over in oregon, but here in jersey we can still go down to our local yamaha bike shop and get brake pads.
  4. XJJeff
    XJJeff Member
    <a href="http://maps.google.com/maps?q=88.583765+4
    You can go to fleabay too.
  5. bosozoku
    bosozoku Member
    Albany, Oregon
    The closest Yamaha dealership is about 20 miles, and they don't stock brake parts for older bikes.
    The Big Brown Truck brings them to my door.
  6. tonymyrs
    tonymyrs Member
    portland, Or
    are you talking about beaverton? What if they are glazed, what should be done?
  7. bosozoku
    bosozoku Member
    Albany, Oregon
    You need to find out whether or not you need to replace your brake pads first.
    Go look.
  8. tonymyrs
    tonymyrs Member
    portland, Or
    I'm at work and its hard to get out for about 11hrs. I'll check tonight
  9. bosozoku
    bosozoku Member
    Albany, Oregon
    No worries. Even though it's warmed up compared to the last two weeks, it's still kinda brisk for riding.
    There should be a narrow vertical slot in the friction material of your brake pads; it's a wear indicator, sort of like the ones on your tires. If the slots are gone, your pads are due for replacement.
    If you do indeed have enough pad material remaining, google will give you a lot of info on the causes and cure for glazed pads.
    Which end of the braking system do you use more, the front or the rear?.
  10. tonymyrs
    tonymyrs Member
    portland, Or
    Its cold but not cold enough, I still ride to and from work everyday just for the love.
    I use the front more because my back one kind of sticks for some reason.
