Lights shift knob
Discussion in 'XJ Technical Chat' started by Igor, Feb 13, 2011.
  1. Igor
    Igor Member
    Santiago CHILE
    Somebody stole the lights shift knob from my bike , just the knob, the one that shift low to high lights, can somebody help me to buy or finde another one.
    From this end of the world THANKS
  2. snowwy66
    snowwy66 Member
    Salt Lake City, Utah
    i think it's called the high beam light switch.
    those dirty rotten b ass stards.
  3. Igor
    Igor Member
    Santiago CHILE
    But they only stole the knob, not the all switch,
  4. bigfitz52
    Igor; This pic is actually of the mirror, but you can see the dimmer switch clearly in the pic as well, over to the right.
    Is that what yours looked like? Triangular, with a phillips screw holding it on?
  5. Igor
    Igor Member
    Santiago CHILE
    hello my friend, that is right, that is the part that this Mf stole from my bike :(
  6. Igor
    Igor Member
    Santiago CHILE
    Now that we know what part it is, what can I do about it, to get a replacement,
  7. RickCoMatic
    In order to get a Feature Item that is a Sub-assembly of a complete Part you'll likely have to acquire the PART and remove the Knob.
    You can get lucky, ... sometimes, ... if you GO VISIT a Motorcycle Junk Yard.
    You might have to go "Look" for it among the "Outside Inventory".
    Giving a Salvage Company a call is worth dropping a dime on them.
    Arm yourself with the Part Number for the Controller.
    >>4H7-83973-00-00
    >>SWITCH, HANDLE 3
    Be able to explain what you want in Junk-Yard-Speak.
    "What are you looking for?"
    "I need a 82, Yamaha, XJ550, Left, Handlebar Control, P-N 4H7-83973-00-00, SWITCH, HANDLE 3, the High~Low Beam Switch, the KNOB for that Switch."
    http://www.drumhillcycle.com/
    http://storage1.colony1.net/2195/Produc ... %20094.jpg
  8. bigfitz52
    Rick, he's in Chile.
    Igor, put a post in "Sell, Trade, Swap" Wanted: High-beam switch lever and see if somebody has one.
    Meanwhile I'll dig around and see what I can find.
  9. Igor
    Igor Member
    Santiago CHILE
    Thanks my friend, there is any chance that you may do the operation for
    me? by know you no me , and also know that there is no problem, with
    money issue..
  10. Igor
    Igor Member
    Santiago CHILE
    Also thanks to Rickcomatic, for all the informatión. Thanks my friend for your concern
  11. MiCarl
    If someone took it they likely didn't unscrew it. More likely they just broke off the lever it's attached to.
    Unless you have a plastic post with a hole through it sticking up there you need more than just the triangular "knob".
  12. bigfitz52
    Carl is right, Igor-- do you still have a clear plastic post sticking up with a threaded hole in it?
  13. Igor
    Igor Member
    Santiago CHILE
    You are right, I have a lilttle piece of plastic coming out of the control, I
    think that is enough to fix it and make it longer to atach the one that it is
    missing.
  14. bigfitz52
    You'll need a picture. I'll get one posted up tonight when I get home if at all possible.
  15. Igor
    Igor Member
    Santiago CHILE
    I´ll be waiting, thanks for your concern.
  16. chacal
    Igor, we should have a good used one available, please send us an e-mail or PM, and yes, we can ship it to Chile!
  17. Igor
    Igor Member
    Santiago CHILE
    Chacal I´m waiting for your replay, I did send you an PM
