Rear Master XJ 1100 upgrade question
Discussion in 'XJ Modifications' started by streetbrawler750, Feb 14, 2011.
  1. streetbrawler750
    streetbrawler750 Member
    Minnesota
    So, I am wondering if any one has upgraded there rear master and with what.
    I am looking to buy a 94 Seca II rear master, dunno if it will work, any help appreciated.
  2. adrian1
    adrian1 Active Member
    Why are you upgrading? Not enough power? The Triumph lads at T595.net went through all this because the Daytona back brake is shite...their solution was to do a simple actuating lever mod to increase lever pressure...
  3. bigfitz52
    From looking at the parts fiche it doesn't look like it will interchange easily.
    I would have the same question, why "upgrade?" How about completely rebuilding the stock system with new pads and a stainless line (after a caliper and M/C rebuild as well?)
  4. streetbrawler750
    Minnesota
    Well, the stock xj part is kind of ugly and I didn't know if something better was available easy to swap.
    I actually grafted an 1100 rear end on my 750, I don't have a stock master, but I do have the caliper, etc.. I am also adapting fz600 rear sets, so I can adapt mounts easy, just wondering about brake fittings sizes, banjo bolts etc.....I guess that would have been useful info to post up in the original post, d'oh.
  5. streetbrawler750
    Minnesota
    Pic of my rear....lol
  6. mlew
    Looks like serious custon fabrication. Post more details please.
  7. streetbrawler750
    Minnesota
    Ya....kind of a teaser pic, would like to get some more done before I post up a new thread. Wating on a part from my local yamaha dealership to finish up the suspension. Called yesterday, supposed to be in today.(fingers crossed)
    I was also looking at a fzr600 rear master swap. Fitz..do you just search for parts fiche? Or have a bunch...does it tell the size of the banjo bolt, or fitting ends?
  8. schooter
    horey sheet!
  9. F.H.
    F.H. Member
    California
    haha... looks like the trailing arm on my truck... thats a sick set up! thats gonna be one smooth ride!
  10. RickCoMatic
    It looks like you know your way around fabricating.
    That's for sure.
    Why not try an XJ-900 Rear Master.
    You'll have to run the Line along the Top of the Trailing Arm.
    You could substitute a Front Master Reservoir off a rocket to save some space.
    It hangs Vertically.
    You need Mechanical Links to connect with the MC Plunger Rod.
  11. streetbrawler750
    Minnesota
    Thanks guys, Rick is do you know, if the fittings are the same to just get a line for the 1100 or 900 and have it bolt up?
    One reason I was looking at the seca II is the availability and frugality of it, and it is made by brembo.
    Did find an 83 900 master on e bay about 10 bucks more, than the duece. I have already spent too much money on this thing! :x
  12. Polock
    the goodridge book says all yamahas use 10X1.25 hardware
    goodridge pdf, page 9
  13. streetbrawler750
    Minnesota
    Cool, thanks polock, I was wondering where to get stainless lines, too.
  14. mlew
    I have gotten several sets of custom length SS brake lines from H-E-L USA. They will make any length with any fittings on the ends you need. I just installed a 7 line set on my Venture. The kit has 7 lines, all stainless banjo bolts, washers and bleed nipples for 300$.
    http://www.h-e-lusa.com/
