Hitachi Nightmare
Discussion in 'XJ Technical Chat' started by behningl, Feb 27, 2011.
  1. behningl
    behningl New Member
    Ottawa, Kansas
    I am having trouble cleaning the orfice in the bottton of the float bowl, does anyone know what size that orfice is?
  2. cutlass79500
    lawrenceville georgia
    Not sure exactly. Fill up the the hole where the pipe goes thru with carb cleaner let it sit for a while then blow it out with compressed air. If that does not work and you have a grinder or wire brush pull one of the bristles out bend it so you can get it in the hole on the bottom of the bowl. The hole doesn't flow to much. I have an ultrasonic cleaner that works well. But you have to work with what you have. good luck
  3. behningl
    behningl New Member
    Ottawa, Kansas
    Yes, I have soaked it for several days and tried to blow them out. No joy. I have one clear and three that are plugged. I will try a wire from a brush, Thanks for the suggetion
  4. RickCoMatic
    Go get the smallest "Number Drill" and roll some Duct Tape at the top of the Shank ... so you can get the bit to twirl between your fingers ... and use it to
    auger a passage through the hardened blockage.
    Once you get some Cleaner to get beyond the blockage, ... the Cleaner will be able to work dissolving the blockade.
  5. behningl
    behningl New Member
    Ottawa, Kansas
    I have some very small drill bits that I can check the size of with calipers, that is why I was wondering what the actual size of the orfice is. What would be the harm if I did open up those orfices slightlty?
  6. RickCoMatic
    Harm?
    No. Not likely.
    The Brass Siphon Tube that extends into the Well regulates how much Fuel is going to be allowed up the Passage when the Plunger is Open.
    Just be sure to get the Intersecting >> DEPTHS << correct.
    Too deep and you put a Drain Hole where you DON'T want one.
  7. waldo
    waldo Member
    San Jose, Ca. 95125
  8. Mr.Etobicoke
    Mr.Etobicoke Member
    Toronto, Canada
    Behning
    You need a #79 drill bit.....and you can get it from XJ4EVER.
    Kenneth
  9. SovereignDragon
    SovereignDragon Member
    Leavenworth, KS
    Ok, the method I used was extremely easy and free. I took a piece of regular electrical wire and stripped off a few inches of the insulation. I took the individual wires one at a time and spun them all in the same direction starting with two until I felt the passage was clean. A quick spray of cleaner into the bottom passage will confirm when it's clean just be very careful and wear safety glasses when you try this for the first time. If you don't hit yourself in the face then feel lucky and remove the glasses, but when you do get hit in the face you will be glad you had them on. Trust me, it happened to me to and it hurts like hell.
  10. RickCoMatic
    Getting a face-full of Carb Cleaner when blasting that Orifice is a Rite of Passage.
    You paid your dues.
    (I also think the Jap Engineers spent some time getting the geometry zeroed-in to make shooting that orifice with Carb Cleaner a surprise for unsuspecting Yankee.)
    jayrodoh likes this.
  11. hardlucktx
    hardlucktx Member
    Allen Texas
    Rick- Dont think you yanks are special it got this Tevan also lol.
  12. hardlucktx
    hardlucktx Member
    Allen Texas
