Poor man's carb sync
Discussion in 'For Sale, Trade/Swap, Wanted' started by todd, Mar 20, 2011.
  1. todd
    todd Member
    Irvine,Ca
    I found this after not having much luck with the 2 baby bottle carb sync.
  2. todd
    todd Member
    Irvine,Ca
    Dam, I tried to attach the picture with no luck. It's a 1x6x 4' board with 4 tubes with 2 "t" fitting @ the bottom filled with ATF.
  3. todd
    todd Member
    Irvine,Ca
  4. RickCoMatic
    If you make one of those things, ... you will have to compensate for the Heavy Fluctuation on Vacuum "Pulses".
    You need ==>> Restriction Devices.
    Restriction Devices are (Hose Unions) which have (Carb Cleaner Red Tubes) epoxied through their center.
    RESTRICTION DEVICES
    (Notice Red Tubes in the Center of the Hose Unions)
