1985 Xj700 no Dim Lights
Discussion in 'XJ Technical Chat' started by ramclain, Mar 22, 2011.
  1. ramclain
    ramclain New Member
    I have a '85 xj700 Maxim and the dim lights have never worked since I've had it. It's not really that big of a problem, just annoys me. It has a good light. Is there a fuse just for the dims, or maybe the switch has gone bad?
  2. steve71100
    steve71100 Member
    memphis, tn
    i have an 86 xj700 and the same happened to me while on a trip. the bulb ended up being bad. i replaced it and it has been working fine ever since.
  3. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Do the obvious first, check the bulb. If that's not the problem, then take the switch apart and clean it. Or check the wiring.
  4. ramclain
    ramclain New Member
    Changing the bulb was the first thing I did.... There seems to be nothing at the switch. the yellow wire works and the green doesn't. I don't have a manual or anything, and don't know where the problem could be.
  5. bigfitz52
    In the switch or the wiring, as "D" said.
    You're going to need a manual or at the very least a wiring diagram.
  6. ramclain
    ramclain New Member
    Right. I ttok the switch apart, and it does nothing except on the high beam.
