Speedometer ???
Discussion in 'XJ Technical Chat' started by Kracket, Apr 8, 2011.
  1. Kracket
    Kracket Member
    Spokane WA
    took a 102 mile trip out to a friends house and back today was fantastic weather... Bike ran good still needs some tuning…
    My Speedo is about 2 miles an hour fast in the 30mph aria and when i took it out on the highway it was reading 45mph fallowing a car in a 60pmh aria when i speed up to the 60mph on my bike i pass everyone... is it normal that the Speedo is correct in the lower speeds and that far off in the higher ones?
  2. BlkMage
    BlkMage Member
    Stead, NV
    Sounds like the spring is wearing. Same thing was wrong with mine, I'm just buying a whole new speedo.
  3. bigfitz52
    No spring is wearing. More likely it's gummy: http://xjbikes.com/Forums/viewtopic/t=15303.html
    or the cable needs to be cleaned and lubed.
    Keep one thing in mind: Even all cleaned and "freed" up and with a brand new cable, it's not going to be the most accurate thing in the world, but they generally read a little FAST at higher speed.
  4. Kracket
    Kracket Member
    Spokane WA
    WOW that is a detailed how to!!! Thanks
  5. bigfitz52
    You're welcome. If you like that one, you'll like the other ones I've done on valve adjustment, clutches, tach drive oil seals, exhaust gaskets, petcock rebuilding, and I forget what else. Look in "FAQ Suggestions."
    I try to fill in gaps in the manuals.
  6. Kracket
    Kracket Member
    Spokane WA
    sweet im gana need all of it here soon my clutch is hanging up a bit. and i had the petcock on prim thinging it ment the same thing as on a truck idk why i thought that...
