Rear Shock Modification Mod
Discussion in 'XJ Modifications' started by BillB, Apr 10, 2011.
  1. BillB
    BillB Active Member
    Tulsa Oklahoma
    Ok, Long story short I bought shocks off Craigslist on the cheap to use on my bike. Since I bought them on the cheap and they are worth over $600 I am using them one way or another.
    This is the shock question and the bottom picture shows my issue.
    These shocks were made for a harley. I want to build out the thickness of MY metric bolt with something (electric tape, bubble gum (j/k)).
    Any useful ideas at all will help. USEFUL IDEAS
  2. hardlucktx
    hardlucktx Member
    Allen Texas
    Take the bolt to Home Depot and see if you can find a peice of hard copper you can use as a bushing.
  3. BillB
    BillB Active Member
    Tulsa Oklahoma
    noted
  4. hardlucktx
    hardlucktx Member
    Allen Texas
    If you have to Bill you can get it alittle bigger than the bolt. Use the dremel to slice some out of the center and squeeze it to fit. I have use that method on several project were I needed a bushing.
  5. BillB
    BillB Active Member
    Tulsa Oklahoma
    I like what you are saying but, I cant figure out what you mean. LOL
  6. hardlucktx
    hardlucktx Member
    Allen Texas
    use the copper to slide over the bolt to take up the space in the shock mount. if it is too big for the bolt slice down the center of the copper the length of the peice allowing you to close the inside dia. of the copper around the bolt.
  7. stevestrom
    stevestrom Member
    I think he means if you can't find one the exact size get a slightly larger diameter copper tubing and cut down the side of it so that it can be 'compressed' smaller to fit.
    Think piston ring.
  8. BillB
    BillB Active Member
    Tulsa Oklahoma
    understood
  9. uhoh
    uhoh Member
    BC, Canada
    Since it looks like the rubber bushings are pretty shot (might be wrong!) it wouldn't hurt to call up progressive and get them to send you a new set of metric gear. I can't remember how much it cost but it wasn't much and it was a very painless process.
  10. bigfitz52
    New shocks come with a whole bag of spacer sleeves, and I only ever use 2, or 4. The rest go in a parts drawer.
    What's your OD and ID required? Maybe I have some that will fit.
    If not, get Progressive to send you a set of metric hardware, as suggested above.
  11. BillB
    BillB Active Member
    Tulsa Oklahoma
    I just sent Progressive Suspensions a message to get a quote with shipping included for...
    1. new rubber bushings
    2. new shoulderd sleeves
    Lets see what happens.
  12. BillB
    BillB Active Member
    Tulsa Oklahoma
    just put in my order to ship
    412-4005
    1 - metric hardware set 5011008
    4 - bushing 5025-10
    order number 89Xxx
  13. Saber
    Saber Member
    Reading, PA
    Those shocks are 11" and stock is 12.5.
    Is the 1.5 inch drop pretty significant when you are running these? I would think on the hardest dampning setting it might not be to bad.
  14. BillB
    BillB Active Member
    Tulsa Oklahoma
    I will let you know by Thursday. I'm counting on these being pretty good. I showed them to my brother and he was trying to kill me for them.
  15. BillB
    BillB Active Member
    Tulsa Oklahoma
    All is good with these new shocks. Technology has come a long way.
    They were very easy to install and ride perfect. Thanks for the suggestions all.
  16. ProfessorBooty
    ProfessorBooty Member
    Columbus, Ohio
    I just did the same thing myself with some 412-4022 Progressive shocks. They arrived in the mail yesterday. I called Progressive and they put me through to the tech department. The guy told me what I needed and even threw in an adjustment wrench for free. I ordered a new bushing kit and a metric conversion kit. It ran me $24.95 (or so) plus $10.25 for shipping from Cali to Ohio. Progressive was very nice and great customer service.
    My shocks came with the chrome sleeve over the shock that I don't want and the tech guy even sent me a PDF via email on how to remove the cover. I was impressed.
    The metric kit contains 12 bushings. For my 82 XJ750 I need the thinnest bushings for the top bolts and the thickest bushings for the bottom bolts. You get an extra set for both the top and bottom and have four leftover mid-size bushings. You also get some washers of various sizes, I think 4.
