It's getting there...slowly but surely
Discussion in 'XJ Modifications' started by dwcopple, Jun 2, 2009.
  1. dwcopple
    dwcopple Active Member
    bay city, michigan
    The bike is darn near ready to go, so I went to reassemble the gas tank today and found two pinholes that leak next to each other. I threw a coat of JB weld on the area and we will see if it works. It usually does. Need to order my battery and finish wiring it up and bleed the brakes. Geting close. Now lets just hope tuning that carb isn't gonna be to big of a chore...
  2. Tiny
    Tiny Member
    Battle Ground, Wa
    Sweet. Cant wait to see it 100% put together and ridable. Great job
  3. PaintIt(Flat)Black
    PaintIt(Flat)Black Member
    Sterling, MA
    Few Questions/Comments/Things I noticed
    1. Awesome bike man, it's looking good
    2. What kind of bike is this? a 400?
    3. Do those things come stock mono shock or did you do that?
    3. Did anyone else notice the fairing looks like a triceratops head plate?
    4. Are the Super Bike grips stock, they are the same ones I have, Just curious.
    5. Your crazy changing the carb setup, But good luck and I hope it's successful.
    6. Again awesome bike man, it's looking good
  4. dwcopple
    bay city, michigan
    1.thanks
    2.XS400J Maxim
    3.stock setup
    4.No
    5.It will be
    6.thanks again
  5. 16ozbud
    16ozbud Member
    louisiana
    Looks good. Must have spent a lot of time getting that motor to look that nice. Like the battery box, too. What was it in it's previous life?
  6. dwcopple
    bay city, michigan
    Relic Wall clock package. Motor was hot tanked at the local Caddy dealer when I worked there last year while I had it apart for a gasket kit install.
  7. mikeg
    mikeg Member
    Milton, Vermont
    Looking good! Can't wait to see the final product!
    mikeg
  8. KrS14
    KrS14 Active Member
    St Marys, Ontario
    I'm very interested in how that single carb setup works! Please report back after you get her runnin!
  9. KrS14
    KrS14 Active Member
    St Marys, Ontario
    I like the gold valve cover too. It'd be awesome if they made high temp in that colour, you could do the whole engine ;)
  10. dwcopple
    bay city, michigan
    They do, duplicolor, that is what that is...500 degree rated.
  11. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    Geeez, Thanks dw, now you got me thinking more.....
    Need to check dupli to see if the high temp comes in copper hehehe
    That would look cool....
    Nice job on the front fairing, been drawing a few ideas myself
    .....currently waiting for new tires....
    Some Bridgestone Spitfires coming in
  12. dwcopple
    bay city, michigan
    some pics I took for ideas today...finishing wiring it now.
  13. coachholland
    coachholland Member
    Georgetown, KY
    Love the gold flake covers. That's sharp.
    ZaGhost, they do offer it in Copper. Hard to find anyone that carries anything than plain ol' red around here. I've been wanting to do mine in Titanium Silver.
    BTW... let me know what you think of the Spitfires when you get them on. I have the rear tire on my latest bike that is one. Not sure I'm as happy with it as the Dunlop on my other bike.
    < / end thread hijack >
  14. ZaGhost
    ZaGhost Member
    Will do Coach.... checked around today... couldn't find any copper ... hehe
    Wish their Chrome was High heat ....
    dw, keep us updated... looking great...
  15. dwcopple
    bay city, michigan
    Thanks, I will. I won some mufflers today on eBay so I should have it ready to run by next weekend or so.
  16. dwcopple
    bay city, michigan
    Mufflers are welded on now and intake is re-tweaked to fit carb around shock.
    bike loaded on trailer at welder's house
  17. dwcopple
    bay city, michigan
    yeah buddy! It runs! Too bad my tank was junk. I cut the bottom out of it and sent it to the intake fabricator today to make me a tank for this thing. I can't believe how good it runs without even messing with the carb at all. I am gonna borrow a buddy's digicam with a microphone on it and take a short vid of it running for ya'll to hear. Hope the tank doesn't take him too long...
  18. 550FAN
    550FAN Member
    Minnesota
    That is a sweet setup, like how you did the color scheme and dropped your seat, any probs with the side intake system?, did you have to rejet?
  19. schooter
    hey, whats the single carb from?
    also... for a better ride.... goto a junk yard and fone a piggy back shock from a quad or something... im sure it wouldn't be that much... and it could look good
    umm, who did your intake work and stuff? i may liek to know for the future
    and good job... i wannt hear that thing roar!
  20. dwcopple
    bay city, michigan
    single carb is from a late 80's CR125. It is a Keihin PE 35mm roundslide. They are great performers. The stock shock is fine BTW. No problems at all with the intake system. And it isn't a side setup really, just kinda kicked out to one side to clear the Monoshock. I have not touched the jetting at all. I may raise the clip position on the needle for a smoother transition and may go up one size on the pilot. The fabricator is a guy from thechopperunderground.com He lives in Brighton, MI
  21. dwcopple
    bay city, michigan
    The panel has my ON/Off instead of a key and the red is my start button. the other hole was for a neutral light I decided not to mount. The intake pics show where Dan and I had to cut the intake and modify it to make the kick to clear the Monoshock.
  22. dwcopple
    bay city, michigan
    it's done...stuck in a new motor from a parts bike I got. Used stock carbs/stock jetting, custom made airbox with a HEPA foam filter, gutted sportster mufflers, simplified wiring with OEM kill switch as headlight ON/OFF now.
    Idle is a tad high in the walk around vid. It is adjusted now. Can't wait to log some seat time in it now. Need to adjust the rear brake yet. The front's with that stainless line on there are FIRM!!! Nice.
  23. dwcopple
    bay city, michigan
  24. schooter
    dem grips.
    I really do like that front cowl... how'd chu make it?
  25. dwcopple
    bay city, michigan
    bought it at the Mt. Pleasant bike graveyard. Its from a Yammy IT490 or something. Disassembled, painted, epoxied an H4 55w halogen into the bulb slot. soldered on a ground wire. good to go.
  26. dwcopple
    bay city, michigan
    Yesterday I tucked the wiring a bit more, installed the other Yamaha eBay grip, and scrubbed the underside of the motor with some mineral spirits to clean it up even more.
