Windscreen Sugestions?
Discussion in 'XJ Technical Chat' started by fender512, Apr 17, 2011.
  1. fender512
    fender512 Member
    Oxford, Ma
    I changed to a round headlight off a XJ550 to replace the square on my XJ750.....
    looking for some wind protection but I don't like the look of the 4 foot tall winscreens I have seen online...
    has anyone out there found one that will fit my application and still be a little low profile?
    Thanks!
  2. BillB
    BillB Active Member
    Tulsa Oklahoma
    This is still pretty tall. I found it on xjbikes and the member sent it to me.
    Ive seen smaller but, its a matter of taste.
  3. TIMEtoRIDE
    You can cut down any of these windscreens to your liking.
    Apply masking tape to protect from scratches,
    draw a curved line using pencil and string,
    cut with saber saw or angle grinder,
    finish with a sanding block - done!
  4. fender512
    fender512 Member
    Oxford, Ma
    I did consider trimming one down, I was just hoping I could find one that was to my liking without modification.... Thanks for the suggestions guys!
  5. zap2504
    zap2504 Member
    Middletown, PA
    If the pictured windshield is too large for you, you should look for "flyscreen" (or sometimes "fly screen"). This may be the size screen you are looking for.
    I'm in the process of constructing a flyscreen for my SR250. I got a replacement windshield for a pocketbike off ebay ($4) and will use some aluminum strapping material to construct two side holders to attach to the upside-down pocketbike screen (wide part at bottom, pointy part at top). It will make a very small flyscreen (to just hide the OEM speedo).
  6. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
    If you go small, you WILL be disappointed with the wind protection you receive.
  7. OldBikerDude
    OldBikerDude Member
    Hood River, OR
    I got the S-06 SpitFire made by Slip Streamer and if it were any smaller I don't think I would care for it. I found it to be the perfect size. Just big enough to block the wind from your upper body. You can view it here... It is the top one - http://www.slipstreamer.com/Product/Sport/sport.html .
    They make them clear or tinted but I like the tinted to keep down the glare on your gauges.
    Anyway, it only measures 15" H x 17 1/2" W. I think you would be pretty happy with it. I know I am with mine.
    Old Biker Dude
  8. ScooterRK
    ScooterRK New Member
    Missoula, Montana
    The spitfire makes for a very comfortable ride. Cuts down on wind (and bugs) without interfering with visibility. Only problem I ever had was loose screws...
  9. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Loose screws?!! You need a different partner! LOL
    OK, but seriously. Size matters...I mean with windshields too. Once you go with a larger one (windshield) you won't like anything smaller. There's seems to be some much wind spinning around behind them smaller ones (for me anyway) and I could find one that fit just right. Maybe it's just me...
  10. fender512
    fender512 Member
    Oxford, Ma
    I found a spitfire on ebay for 40 bucks...thinking I am going to order it and try it out...My only concern is will the Atari interfere with the windscreen?
  11. ScooterRK
    Missoula, Montana
    It should fit around the Atari quite nicely, actually. Had it on my Seca. Never tried it on the Maxim, though.
    The wing nuts holding the posts tended to vibrate loose on me. Had one land in my lap one day.
    $40 is a good price. I paid $60 for mine, new.
  12. fender512
    fender512 Member
    Oxford, Ma
    Thanks scooter! I think you talked me into it!
    P.S. Nothing a little locktite can't fix.
  13. OldSchoolOtter
    OldSchoolOtter Member
    Towson, Maryland
    I'm thinking about getting one also. Will that fit ok on an '81 Seca?
  14. ScooterRK
    Missoula, Montana
    Fender- lol!... unless you want to adjust or remove it easily!
    OldSchoolOtter- yes, it's a great fit. (at least for the 750)
  15. Planehue
    Planehue Member
    London,Ontario
    I bought a Spitfire for me XJ. First thing I put on it. It workd good for me. Then I had a battle with gravity. Grafity won, but only the windshield broke. I am now looking at the slipstreamer Hell fire. Any one have or has used one?
