Vacuum Port Manifold?
Discussion in 'XJ Modifications' started by jkurtzb, Feb 21, 2007.
  1. jkurtzb
    jkurtzb New Member
    washington state
    I was reading about a mod that someone did to their carbureted FZ-1. They made a manifold out of fuel hoses that connected the 4 vacuum ports together. They claimed it helped equalize the vacuum variances between the carbs as well as increasing smoothness and performance. Has anyone tried this on an xj?
  2. kevineleven
    kevineleven Member
    Columbus, Ohio
    Yeh, Yamaha did, it's called YICS.
  3. jkurtzb
    jkurtzb New Member
    washington state
    So then, it seems to me, the YICS tools sole function is isolate each carbs' vacuum so that the stick set can "read" them individually?
  4. RickCoMatic
    Bullseye!
    You get to select any prize of the top shelf!
  5. jkurtzb
    jkurtzb New Member
    washington state
    I knew there was a reason I made that YICS tool ...
  6. ArizonaSteve
    ArizonaSteve Member
    Phoenix, AZ
    I tried that once and couldn't tell any difference.
