Speedometer Mod/ easy upgrade.
Discussion in 'XJ Modifications' started by BillB, Apr 24, 2011.
  1. BillB
    BillB Active Member
    Tulsa Oklahoma
    Instead of fiddling around with my 30 y/o speedo I pulled the cable out (after it quit working and replacing it 3 times) and came up with a good ( I think ) MOD.
    Im sure there is a very expensive bracket I can buy for $59.99 but I used something that I have on hand.
    This is a bicycle air pump hanger for a mountain bike. I heated the clasping arms to straighten them out. They mount velcro's onto the handle bars much the same way it did on the bicycle frame tube.
    Next, I put velcro on to the back of my iPhone 4 case to stick onto the pump hangers arms I straightened out.
    The iPhone slips on and off easily but not easy enough for the bumps wind to affect it. I have a 12volt plug to keep it charged on board the bike.
    I can even position it to perform a HEADS UP DISPLAY for easy night driving.
    The apps I use have trip meter that figures MPG and Maps for getting around in unknown territory.
    Can your 30 year old speedometer do that?
  2. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    If you did not use "Industrial Grade" Velcro (in most stores) I would.
    Other than that the Heads Up was cool :)
  3. Polock
    "Can your 30 year old speedometer do that? "
    no, but it is water proof
  4. BillB
    BillB Active Member
    Tulsa Oklahoma
    It'll go in my pockets if I get caught in the rain.
  5. Militant_Buddhist
    Militant_Buddhist Member
    Redmond, WA
    get an otterbox
  6. BillB
    BillB Active Member
    Tulsa Oklahoma
    I will check into that.
  7. Hasersys
    Hasersys Member
    Sebastian and Tampa Florida / Chicago Il
    The case I use on my Iphone speedo is water proof, I just do not know the name of it. The I also tryed the otter box, but after a while the mount it comes with begins to get loose. Although I haven't treid the newer otter box. You might have better luck with that one.
  8. waldo
    waldo Member
    San Jose, Ca. 95125
    Nice Bill!! I like the HUD mode especially.
  9. BlkMage
    BlkMage Member
    Stead, NV
    Though I am a fan of the no windshield method, I LOVE the HUD. Now if I could only put one inside my helmet...
  10. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Hey Bill, sounds like you've got another problem to work out for the masses. Cool trick with the heads up
    As far as the rain, put Velcro on the back of a zip-loc sandwhich bag. :roll:
  11. Hasersys
    Hasersys Member
    Big veiw of mine.
  12. Erman
    Erman Member
    Oslo, Norway
    I'm using a sort of rubbery gum to stick my HTC to the middle of the speedo. I got it from a friend that works in a paint shop... It is easily shaped when warm, and sticks to things very well. Plus, it absorbs vibrations from the road.
  13. Hasersys
    Hasersys Member
    It sounds like Permabond, or perma gum. It is a black sticky gummy like stuff. If it is the same stuff lol.
  14. Erman
    Erman Member
    Oslo, Norway
    Yeah, only I don't know why they put the "perma" in there, it's not permanent, hehehe
  15. Hasersys
    Hasersys Member
    Yeah, not sure. I use it alot on the airplanes I built for a bunch of different things. Mainly sealing spots to keep moister out.
