Silicon Grease - Sourcing??
Discussion in 'XJ Technical Chat' started by Smooooth, May 2, 2011.
  1. Smooooth
    Smooooth Member
    Syracuse, NY
    What a great day - parts arrived from Chacal...................
    Scary how such a little package can cost so much and yet provide so much joy.
    Back to the Grease - Time to put the carbs back together.
    I could not find Silicon Grease locally with the exception of NAPA at $30 for 8oz. Ebay has nice little 1/4 oz tubes for about $4
    I have searched many a post on the forum and have seen some conflicting information.
    Somewhere I saw a post about looking in the plumbing section of hardware stores.
    Any help as to where else to look would be greatly appreciated.
    Did I miss something from Chacal? (Maybe a hint for him to carry)
    Thank you
    Stephen
  2. mlew
    Auto parts store sells small packs for spark plug boots.. couple of bucks.
    O-ring lube at the hardware store is silicone grease.
  3. schmuckaholic
    California
    I've had no problem sourcing it locally, but Chacal does indeed stock the stuff. Ask for HCP1714.
  4. OldBikerDude
    OldBikerDude Member
    Hood River, OR
  5. SQLGuy
    SQLGuy Well-Known Member
    Silicone, actually.
    Easiest thing is in the plumbing department of your local hardware store. Should be a couple of bucks for a small container of it.
  6. c_muck
    c_muck Member
    Minneapolis, MN
    Yep, I found a little tube at O'Reilly's that was labeled for spark plug boots. 100% silicone grease.
  7. Smooooth
    Smooooth Member
    Syracuse, NY
    GOT IT!!!!!
    In the Plumbing Department at the hardware store.
    $5.00 for a small container that will last a loooong time.
    Carbs have now been reassembled - next task is Bench Sync
  8. bigfitz52
    Float levels?
  9. Smooooth
    Smooooth Member
    Syracuse, NY
    To quote Shrek - "It's on the to do list"
  10. nachtfrost
    nachtfrost New Member
    $30 for 8oz? D:
    Don't think I've seen that at my store!
    Anyhow, great tip on the hardware store one.
    Have fun! ;)
