need a higher mph speedo
Discussion in 'XJ Modifications' started by sirbuick, May 4, 2011.
  1. sirbuick
    sirbuick New Member
    I'd like to get a higher mph speedo for my 82 xj650, but I'm not sure which models would have had one or what would fit. Any ideas?
  2. JFStewart
    JFStewart Member
    Ontario Canada
    No one "needs" a higher mph speedometer. How fast do you expect to go? Is this a racing machine? If so you don't need a speedo on the track. The stock speedo exceeds any known speed limit.
  3. bigfitz52
    Horsefeathers.
    One way is a "transplant:"
    The actual instrument itself came from (I believe) an XJ900; only slight modification was necessary to drop it into my cluster.
    I like how the speedo needle and tach needle are now at pretty much the same relative radial postion in top gear; like in my car.
  4. JFStewart
    JFStewart Member
    Ontario Canada
    It is pretty. I can see why you may want one, but I still don't think its needed as the topic states.
  5. cutlass79500
    lawrenceville georgia
    definitely looks much better then those 85 mph units in the early 80s. Think they went back to higher ones about 83 or so if i am correct. My 85 is 135 stock. I have a 150 but see no need for it
  6. JFStewart
    JFStewart Member
    Ontario Canada
    My 550 Maxim speedometer goes to 140 MPH or 220 KPH. Never been that fast on a bike.
  7. bigfitz52
    Right. But the USA-market bikes came with 85mph speedos. When I'm coming up to a corner, at "somewhere" above 80mph, I'd like to know how much over 80 I'm going, not have to slow down until I get back into the speedo's "range."
    Besides, I like having the needles moving in unison in top gear, like I said.
  8. JFStewart
    JFStewart Member
    Ontario Canada
    Didn't realize the US bikes came with a speedo so low. Just figured they would be the same range without the KPH reading on it.
  9. bigfitz52
    I was an attempt to get us to all drive 55mph during the first "gas crisis." Thankfully, the regulation only lasted from September of '79 through October of '81. (Passed as a result of the 1973 fuel crisis. Gotta love the Fed's timeliness.) But since Yamaha built most of their '81-'83 bikes from the same parts, it hung around a bit longer than actually required. MOST '83 M/Y bikes escaped it, except those that were using "earlier" speedos, like the 550s.
  10. kevineleven
    kevineleven Member
    Columbus, Ohio
    Mine goes to 999. I've not gone that fast though.
  11. GFunk
    GFunk Member
    Florida
    I highly recommend it....... on a track of course :D
  12. JFStewart
    JFStewart Member
    Ontario Canada
    There's a track that allows public access and runs courses on high speed riding near here but I'm in my sixties and my reflexes aren't what they used to be. I have been very fast in my younger, foolish days but now I prefer a leisurely ride on a twisting scenic route.
  13. bigfitz52
    There was a time, when the bike and I were younger, that I made a point of getting my Norton up over 100mph at least once a season. While it probably will still do it, I won't.
    Do it to that old bike, that is.
    That's what I have an XJ for.
  14. Carvall
    Carvall Member
    Seattle
    LOL I like your comment.
    My friends have newer bikes and they are always amazed that Im always right behind them and sometimes when I feel enthusiastic in front of them.
    XJ's are quick and fast.
  15. Carvall
    Carvall Member
    Seattle
  16. sirbuick
    sirbuick New Member
    Okay, I don't NEED a higher mph speedo, but I WANT one! I think it's perfectly reasonable for my speedo to display at least my bike's max mechanical capability which I understand is in the 120mph range. And I regularly exceed "known speed limits" That's why I got a bike in the first place and man is it fun!
