Mileage
Discussion in 'XJ Technical Chat' started by gbuddyjoe, Feb 23, 2007.
  1. gbuddyjoe
    gbuddyjoe Member
    New Hampshire
    Hey all,
    What is the standard gas mileage that I should be expecting out of my 1983 XJ650 Maxim? I just got it as a starter bike and am curious what it will be needing for gas come this summer.
  2. bosozoku
    bosozoku Member
    Albany, Oregon
    You should get ~45 mpg, if the bike is running right. It's mostly a function of how much you twist the throttle.
    Use regular gas, not premium, regardeless of what the Hog-nobs tell you.
  3. Fraps
    Fraps Member
    Kitchener, Ontario, Canada
    Bosozoku - can you shed some light on your regular vs premium preference? I always thought the premium was better for performance, mileage and engine life.
  4. bosozoku
    bosozoku Member
    Albany, Oregon
    There is no more energy in higher octane pump fuel than there is in 87 octane regular. Period.
    The only way to exploit the higher octane is to have enough compression, or boost, that you need to use the spendier gas. Otherwise you're paying for a fuel quality that your engine can not take advantage of.
    It's not strictly a matter of compression- my 900 has 11:1, my FZR600 has ~12:1, and both are happy with regular gas. A large combustion pocket with an older design, like the last centurys' HDs, will detonate at 9:1 c/r on regular fuel when under a sustained load.
    I've got a link that explains it in better detail...Let me see where it is. :)
    edit: bikes obey the same rules as car engines- http://www.freerepublic.com/focus/f-news/1770628/posts
    Take a look at ch 6.13 on the third page of this article- http://www.cs.uu.nl/wais/html/na-dir/autos/gasoline-faq/.html
    Your engine will make the best power on fuel that has just enough octane so it does not detonate- anything more goes to waste.
  5. Fraps
    Fraps Member
    I knew cheaping out on the regular was going to pay off! As much as I thought premium was better - I never actually ran it in any of my vehicles.
    Thanks for the info.
  6. Danilo
    Danilo Member
    Vancouver canada
    Serious ly think on that one :)
    Yama specifies Premium.. There are not joking with comp ratios usually above 10:1 on these things .. the risk of detonation is real and Holed pistons can really mess yr day. Those couple of dollars "saved' may not feel so good in yr pocket when that happens.
    My experiences are that even 91 is iffy.. producing significant ping and a v noticeably reduced 'snap' in throttle response. In order to adequately run low test either the comp has to be lowered and/or the ignition timings significantly retarded.. Simple Physics ..no amount of 'Belief' is going to change reality.
    IF yr Yama runs OK on 'Regular' then it's in real need of Work.
  7. Fraps
    Fraps Member
    Alright, I'll think on it.
  8. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I run premium on real hot days because it runs cooler. But regular is good enough for everyday riding.
  9. bosozoku
    bosozoku Member
    Albany, Oregon
    No, the Yamaha shop manual specifies regular gasoline, and makes no mention whatsoever about premium.
    The same manual lists my 650 as having a CR of 9.2:1
    Haven't got the 750 manual handy, but the big ones' is-
    The 900 is 9.6:1, with the same fuel requirement. Regular
    Would you please break out the manual and take a look at reality before you spit numbers out?.
    But, if putting premium in the tank makes you happy, by all means do so.
  10. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    I tend to run regular on the most part.
    On occasion when I know I'm going to twist it I use Premium.
  11. Fongdingo
    Fongdingo Member
    Charlottesville VA
    This helps alot, I was told by the PO of my bike that i should only run the prem gas. so i have, i think now im going to take Hvnbnd advice and only put that in when im going to twist. Thanks
  12. Danilo
    Danilo Member
    Vancouver canada
    Well...if yr happy then Enjoy :) Yr saving a huge Dollar on a fill-up :)
    All I can say is mine is at 10:1 comp (Owner's manual) and it without doubt 'pings' like crazy and runs poorly on Regular.. but then so does my '71 Beetle with it's 7:1 compression aircooled engine.
  13. Nick
    Nick Member
    Vernon, BC Canada
    Danilo, what model bike do you have?
    My Yamaha service manual shows the XJ750 and the XJ650 both have 9.2:1 compression ratio. My XJ750RH owners manual says to use regular gas.
    I plan on trying both grades of fuel and see what my bike tells me.
  14. chacal
  15. bobc
    bobc New Member
    alabama
    I have been using premium in my bike for a year now. not much more go then regular but i heard that the premium gas does not leave as much carbon buildup as regular. i could be wrong. can any one shed light on this.
  16. Polock
    first a question then some BS
    is octane rated the same way now as it was back in 81, 82 ?
    i give Mr Ed the expensive stuff 'cause it gives me that warm fuzzy feeling
    it's a karma thing
  17. Gearhead76
    Gearhead76 Member
    Appleton WI
    Premium will burn cleaner but not give you any more bang for your buck unless you have turbo or supercharger, If you get a ping then I would check your timing, If that's right then run the higher octange, It's hard to find higher octange around here without ethonol, But since bikes don't have converters to worry about like cars then don't see a problem, The ethonol makes the fuel burn cleaner but you lose some of the punch. Certain cars too much ethonal will mess up o2 sensers and converters.
    Thanks my take on it anyway.
  18. Hired_Goon
    Hired_Goon Member
    Oz
    Pinging is usually caused by one of two things. Generally, as Gearhead has stated, ignition timing is the main cause. But a lot of Yammies are fixed ignition and can't be adjusted. Other timing issues can occur of course. Definately worth looking at in case a PO has "modded" the timing plate. A mate bought a brand new XJ900 Diversion in the early nineties and it pinged out of the box. Dealer fix was to elongate the non adustable timing plate holes. 8O
    The other choice is mixture. If it's running too lean then light pinging can occur. Particularly once the engine temp gets up a bit. Try a quarter turn richer and see if it makes a difference.
    I can't think of any manufacturer of any vehicle prior to 95 recommending use of anything other than regular.
  19. samsr
    samsr Member
    Colorado Springs
    octain ratings in different parts of the country are different. Primeum here in colorado springs is 89 octain. Good luck finding 91. The cheep stuff is 85 octain and mid is 87. And we pay just as much for the 89 crap out here as you pay for the 91 elsewhere in the country. I run the 87 and dont have a problem. Keep in mind I am at 6000 feet. So as to theoretically need lower octain. Beats me how it all works.
  20. capy
    capy Member
    Florida
    The specifications on the inside of my 85 xj700 actually call for 91 premium. It also states that I should be using regular not unleaded. It is the original cover. I have even gone so far as to use a lead substitue in mine for this reason. I am concerned that the valve seats are not hardened and might recess into the head witout it.Since there is no catalitic converter on my bike, I would believe the extra lead will help the longivity of the engine and the valve seats. I also usually run the high test 93-94 octane due to the amount of stop and go traffic I encounter which keeps my engine extremely hot in my daily driving. 45,000 miles and still runs strong.
  21. Gearhead76
    Gearhead76 Member
    Appleton WI
    I don't thinks any thing calls for leaded gas since the seventies, but I could be wrong
  22. RickCoMatic
    Capy:
    You're doing the engine a favor running the good stuff. I ran high-test all Summer because the bike was pinging on the Ethanol-added Regular that was getting served-up.
    I don't think you even need the lead additive; though. But, if the bike's been running "Real good" on the way you blend your fuel ... all the "More Power" to you Cappy.
    Happy Riding!
  23. Alive
    Alive Active Member
    Queensland, Australia
    Interesting.... Over here the low octane is 91, high is 95 or 96. One gas station even sells 98 octane.
  24. KiwiXJ750D
    KiwiXJ750D Member
    New Zealand
    I have been running my old Holden Commodore (1984) with a 3.3 litre/202 cu inch 6 in it on 95. All my older Holdens would ping like crazy on 91 but have now switched to 91 on the Commodore, no ping or other "bad things".
    Ran 95 in the XJ, and with having to take the pipes off for collector box repair I had a look. The exhaust ports are very sooty @ 500 Km since they had been cleaned spotless when I rebuilt. (plugs are fine).
    When all is back together will try 91 and see if pinging happens.
    Guess the sootyness might be because of 95 Octane???
  25. Alive
    Alive Active Member
    If your plugs are sweet, not likely to be mixture (you can adjust mixture on injection?) Then yea I'd give 91 a crack and see what it's like.
    I might have a look at the additives available over here to see if they make any difference too.
  26. KiwiXJ750D
    KiwiXJ750D Member
    New Zealand
    Yeap, the injection is not adjustable. Been running Caltex "Clean as you drive" 95 Octaine. If 91 don't ping will switch.
  27. Alive
    Alive Active Member
    I'd be interested to know if it makes any difference.
    I've been running the 900 on 91, but hard to know when travelling such short distances and needing a tune. Sometime this year I'll get my tank back *sigh*
  28. woot
    woot Active Member
    One big note. Octane is measured differently in different places.
    RON and MON. To early for the math. The same gas in different places will have a different stated octane - based on how they chose to calculate it. If you read the manually carefully it will say something about the way they measured octane - it might say 91 RON for example. ( http://en.wikipedia.org/wiki/Octane_rating )
    The bike is designed for 87. I have tested my 650 maxim with regular and supreme back to back and I have >20,000 miles of fuel receipts in an access database. It makes no measurable difference.
    Run 87. IF there is pinging or other weirdness you can either investigate carbs/valves or you can try higher octanes.
    Regular is not crap gas they're trying to pawn off on you. Despite your best intentions of serving your maxim the best wines available, instead of regular cooking wine, your maxim doesn't care. She is a gas-pig and she'll drink anything to get her engine going.
    Now ethanol = I have heard of people having problems with it, particularly older motorcycles (Which all tend to be carb bikes)... this is a special case and might require a higher octane. We don't have that issue here.
    tafn,
    woot.
  29. RickCoMatic
    The injection should be adjustable within a very narrow limit. I don't have the literature on the Motorcycle's ... there isn't an injected oldie anywhere around here.
    But, I think the process of adjusting the F/I Mixture involves tweaking the return "Signal" of the Oxygen Sensor to make the Fuel injector's Open-Closing frequency duration a bit longer or shorter as needed.
    The millisecond higher or lower, of the fuel injector's open/closed frequency, needed to keep the content of O2 in exhaust gases within the dialed-in limit, enriches or leans-out the mixture within a very narrow band of adjustment.
  30. chacal
