basic questions
Discussion in 'XJ Technical Chat' started by 83xj650, May 15, 2011.
  1. 83xj650
    83xj650 New Member
    Missouri
    hey, i bought a 83 maxim 650 from my gramps last year and now that its starting to get nice outside id like to start riding it. BUT it wont start lol. the lights turn on and blinkers and horn work but when i push the start button i hear a rapid loud clicking from the..... starter solenoid? (the round thing right behind the batterie) i put my voltmeter on it and it was only reading 10.8v. And the oil level light turns red.
    so this is what i did so far,
    Put the battery on trickle charge
    drained the oil,
    now, what kind of oil do i use and how much, also where is the oil filter. lol
    this is my first bike and it did run very well last fall.
    also the bikes electrical system is in pretty crudy shape...but its a work in progress.
    thanks!
  2. BlkMage
    BlkMage Member
    Stead, NV
    Step 1, get yourself a repair manual. My Haynes book has helped me out quite a bit.
    Oil filter is inside a cylinder sticking out the front/lower part of the engine. Look in between your pipe headers. Should have a bolt head (bypass bolt system) to remove in order to pull the cylinder and replace the filter inside. Standard motorcycle engine oil (no "friction modifiers") should work just fine, I run 20w50 myself.
    Few other things to check before you start riding. Rear brake shoes, old tires, fuse box, clean carbs...just keep reading here for a bit, LOTS of good info to be had.
  3. 83xj650
    83xj650 New Member
    Missouri
    i do have the manual on order. how do i know when the oil level is full? i see the sight gage but there is no dipstick or fill oil to here line lol.
    thanks.
  4. BlkMage
    BlkMage Member
    Stead, NV
    When the bike is on the center stand you should get a round bubble at the top of the glass. If you just ran the bike, give it a few minutes to drip down. Also, by the fill port should be a number stamped into the case giving the oil capacity, but most of us seem to put just a bit extra in. If you're changing the filter (which you should) at the same time, it'll take about 3,000cc extra oil.
    Also, this is a shaft drive, so you have gear oil in the gearbox beside the rear wheel. 80w90 Hypoid oil is what you put in, the "level" is the bottom of the fill port when the bike is on the center stand.
  5. bluesdog
    bluesdog Member
    Similkameen BC Canada
    +1 on "other things to check before you start riding. Rear brake shoes, old tires, fuse box, clean carbs..."
    Before doing the oil and oil filter change, make sure you have new o-rings for the filter housing and the bypass/bolt, and a fresh 'squash washer' for the drain plug. And install the new filter correctly: with bolt inserted in the filter housing -- spring, washer, filter.
    Tighten the bolt only enough to compress the housing o-ring against the sump surface. Make sure the mating surfaces are clean, and you won't have to worry about oil leaks.
    Avoid over-filling the system, since too much oil can stress the oil seals
    You may need to use penetrating oil on the rear gear oil filler bolt
  6. 83xj650
    83xj650 New Member
    Missouri
    will seca 650 carbs work on my xj 650 maxim?
  7. TIMEtoRIDE
    Yes - - they're even jetted a hair richer for added performance.
  8. bigfitz52
    He meant 300cc. (Extra.) The little number cast into the clutch case right by the filler is your oil capacity, I believe yours says "2500CM3" which means 2500cc's. Add 300cc or so to keep the oil light happy, and you're at around 2800cc total.
    Then follow the advice about having a slight "bubble" at the top of the oil level window when the bike is on the centerstand and has been OFF for at least 10 minutes.
  9. smoak
    smoak New Member
    WA
    Do you know where I can get o rings in the US? I need one for the filter housing and the bypass/bolt. It doesn't seem like local shops will have them :?
  10. bluesdog
    bluesdog Member
    Try the locals first, but if they don't have the parts you need, you can probably order 'em on line
    Or possibly flea-bay
    Someone else here may have another suggestion for finding these common parts. I think Yamaha used the same oil-filter setup on a number of bikes, for many years, so the parts shouldn't be too hard to come by.
  11. bigfitz52
    FRAM CH6003 oil filters COME WITH both o-rings; and are widely available. Advance Auto and Murray's/O'Reilly commonly stock them.
  12. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    O'Reilly's, I love O'Reilly's :D . I go to the one in Port Huron MI when ever I'm in Sarnia. The parts are so much cheaper then here in Ontario. OH, sorry... I was just getting nostalgic here. Yes O'Reilly's and The Golden Corral AHHHHH :lol: .
    Ya the gaskets come with the Fram filters...even in Canada. It really irks me when I see them listed for sale on flea bay, ahhhhhhhh :twisted: .
  13. smoak
    smoak New Member
    WA
    Yeah, I ended up getting a K & N filter off their site and it didn't come with an o-ring :x I'll check with my local O'Reillys and see if they have an o-ring for me. Thanks
  14. bigfitz52
    When I said O'Reilly's stocks them I meant FRAM CH6003's not the o-rings separately. (Although they might.)
  15. smoak
    smoak New Member
    WA
    Yeah, I called my local one and they have a section of o-rings so I can just bring my old o-ring in and see if I can find it. If not then maybe I'll look for that fram oil filter since it comes with the o-ring already and it'll probably be easier than trying to find the o-ring on it's own :roll: Thanks for the info :)
  16. Triple_P
    Triple_P Member
    NJ
    In regards to the filter replacment. I have the correct order....bolt, spring, filter. But I wasn't paying attention when I took the filter off...there is an indent on one side, and the other side pokes out a little. Which way does the filter go back in the case? I'm assume you put the side that pokes out in first so that before you put the case back on, you see the side that indents and that's indent side is what sits against the bike.
    Right??? :)
  17. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    After cleaning everything:
    New washer on the bolt
    Bolt into the housing
    SPRING onto the bolt (I forgot the spring the first time I did an oil change, and believe me, oil runs out quite steadily)
    Filter onto the bolt, inside the housing, with the indent side against the spring.
    Re-install housing.
    The spring pushes the flat side of the filter against the block.
    REMEMBER- only torque to 11ft-lbs
  18. Triple_P
    Triple_P Member
    NJ
    son of a.....
    i had a 50/50 chance and guessed wrong... i put the indent against the block....
    welp, good thing i have some oil left over..
  19. Triple_P
    Triple_P Member
    NJ
    thats what happens when you have the patience of a 5 year old and can't wait for your haynes manual to get here OR for a reply on a forum...
    but thank you tskaz
  20. tskaz
    tskaz Active Member
    Lucky part for you is that you can take the filter housing off, correct the mistake, and put the housing back on, without losing too much of the oil. Just pull the housing back off without opening the drain plug.
