Should my bike stay running if I....
Discussion in 'XJ Technical Chat' started by KINGKAOS, Jun 5, 2011.
  1. KINGKAOS
    KINGKAOS New Member
    With my 82 xj750 after I start it. If I take off the pos. wire from the battery. Should it stay running? OR shut off?
    Cuz my bike shuts off when I do that... My buddy was like "Dude that isn't supposed to do that!!!"
    Thanx
  2. BillB
    BillB Active Member
    Tulsa Oklahoma
    I am sure it is normal for it to die. No magneto.
  3. KINGKAOS
    KINGKAOS New Member
    Thats what I thought.. I just wanted to check. Thanx
  4. SQLGuy
    SQLGuy Well-Known Member
    Also not good for the regulator.
  5. cutlass79500
    lawrenceville georgia
    Be very carefull doing that you rev it up a little and you will blow every bulb on the bike not good for tci coils ect. I was working on a maxim that has the inline fuse by the battery when you give it gas it would loose connection all the voltage spikes think you could see right thru someone the headlight gets so bright they it backfires and stalls usually takes out smaller bulbs first
  6. autosdafe
    autosdafe Member
    Lorain OH
    On a car that's a way people used for checking the alternator. These bikes don't work the same way.
  7. cutlass79500
    On older cars if you do it on computer controlled cars your asking for trouble
  8. autosdafe
    autosdafe Member
    Lorain OH
    Well yeah I meant older cars LOL. Newer cars will just tell you that it went bad.
  9. KINGKAOS
    KINGKAOS New Member
    FYI I didn't mean to disconnect the pos. cable while the bike was running.. I had lost the terminal screw n had the cable "stuffed" in there... Then I hit the cable with my leg n it disconnected. I got a new screw n all is fixed :)
