love my bike...but i got questions
Discussion in 'Hangout Lounge' started by santos750, Jun 11, 2011.
  1. santos750
    santos750 Member
    winnipeg manitoba canada
    Hi fellow XJers. When I was a kid i remember lookin at one of these Maxims when they were brand new and thinkin....WOW, I want one some day! 28 yrs later...here I am, 1983 XJ750 with 29,000 kms. I'm actually a first time rider and this is my first bike. What a way to get introduced into biking, what a great bike. She runs great and can keep up to the newer cruisers like a champ. But with age comes issues, Right? The one that bothers me the most is the turn signals. At idle they just stay lit but no blinking. I rev up and they flash. Battery is good and charging system is correct. Can anybody help?
  2. JFStewart
    JFStewart Member
    Ontario Canada
    Give us numbers. A fully charged 12 volt battery should be about 13 volts. During cranking it should be at about 10 volts. At idle the system should be at just higher than battery at rest and at high rpm it should be about 14.5 volts.
    The flasher works on a thermal principle and requires certain voltages to produce the heat to activate. If you have dirty connections or poor grounds in the circuit it will cause a voltage drop that will affect the flasher.
    You need to start at the battery and then follow the circuit to each connection point and check for corrosion. This would include the ground side of the circuit as well.
  3. bigfitz52
    What you ought to worry about first and foremost is ensuring the rear brake isn't going to suddenly lock up on you. Read this: http://xjbikes.com/Forums/viewtopic/t=15874.html Serious business.
    Pop the bulbs, check and clean all the sockets; you'll be surprised how nasty they can be and still work sometimes. That being said, unless your battery is indeed 100%, such behavior is normal. The charging system isn't doing much until you get well above 2K rpm. At idle the battery is doing all the work.
  4. santos750
    santos750 Member
    my battery is fine(new) charges to about 14.2 at 2000rpms....somebody told me to change the flasher to a newer one
  5. TIMEtoRIDE
    Add a fusebox upgrade/replacement, inline fuel filter, rider safety course, tire date code check and a GPS !!
    Welcome !!
  6. project1
    project1 Member
    central pennsylvania
    fusebox fusebox fusebox...even if it isn't your problem now, it eventually will be...trust me or you'll be chasing gremlins that don't exist.
  7. RickCoMatic
    A Non-Blinking Signal Light very often is simply a Bulb issue.
    Do you have a Burned-out Bulb on the Rear Signal?
    "I rev it up, ... and they Flash" (Very common)!!
    Inspect your Alternator Brushes and the "Orbit Paths" of the Alternator.
    If the Brushes are 10mm or less, ... Replace!
    If the Circular Paths on the Rotor are "Scorched" and very dark, ... Remove the darkened circle.
    Use an Eraser.
    Specifically, a "Typewriter Eraser" made from Pumice.
    http://www.amazon.com/Venus-Circular-Ty ... B003KEFV02
  8. santos750
    santos750 Member
    bulbs are all good and yes, i've already upgraded my fuses
  9. OldBikerDude
    OldBikerDude Member
    Hood River, OR
    What kind of battery charger are you using on it?
  10. santos750
    santos750 Member
    same one as on my car but 2 amp trickle charge
  11. OldBikerDude
    OldBikerDude Member
    Hood River, OR
    It was actually a test question because some people think that there battery is fully charged but it really isn't and when it isn't fully charged things like this happen. This happen to me once but then I brought my battery back up to 100% and all was well again.
  12. BillB
    BillB Active Member
    Tulsa Oklahoma
    It sounds like your charging system is failing slightly.
    I'd def have to side with Rick.
  13. santos750
    santos750 Member
    thanks guys. think i'm gonna go back to square one .......check the charging system in detail.
  14. RickCoMatic
    You might be a victim of age.
    Resistances built-up at Bullet Splices.
    It's a bit of a tedious job. A good rainy day project, ...
    Open the Headlight Bucket.
    Undo and re-connect the Wiring Splices.
    Crimp the Barre-ends closed tighter so the Bullet fit snugly.
    Check Bulb Sockets for dried-up Grease.
    Clean.
    Run Emory Board over Bulb Contacts.
    Make sure all Grounds are good.
    Test Flasher. (Tap on it ... Replace.)
    Low Power in System.
    Ck Battery.
    Ck Alt Brushes
  15. santos750
    santos750 Member
    so...after a long winter i finally got to it!! i opened up all the signals one was corroded...cleaned it up added some electrical contact grease and new bulbs. i opened up the headlight bucket and cleaned all the contact connections. The one that made the biggest difference was changing the signal relay. I found a thread here about this relay that I found at a part store ,I had to switch 2 of the wires but that was the fix.
  16. lostboy2
    lostboy2 Member
    Crimora, Va
    Glad to hear you got it worked out. Sometimes electrical issues can be so aggrevating.
  17. tumbleweed_biff
    tumbleweed_biff Active Member
    Gahanna Ohio
    Congrats!
    BTW what is the part #/brand of the relay for the rest of us?
  18. santos750
    santos750 Member
    tridon part# EL13. Only thing is u lose the self canceling :( I found the toss up worth it though.
  19. tumbleweed_biff
    Gahanna Ohio
    Ah. I was hoping you found one which provided the cancellation. A couple of people created their own and posted some information here, but I was never able to dig up enough info that someone as ignorant of elecronics/circuit boards as I could reproduce.
