engine noise
Discussion in 'XJ Technical Chat' started by bossone60, Jun 20, 2011.
  1. bossone60
    bossone60 Member
    i have xj750 seca the motor seems to make alot of noise after warming up is this normal or should i use heaver oil
  2. mlew
    Depends on the noise, could be a major problem or noisy valves. Since you indicate its only noisy after the engine is warm I suspect you need to check valve clearences. The first thing is to check the valve adjustment. Changing oil is not a solution for engine noise.
  3. parts
    parts Member
    prescott valley az
    You need to define that a little.
    Engines can make all kinds of noise for many reasons.
    Xj motors are noisy by nature. You SHOULD hear the tic from
    the cam lobes as they work over the shims.
    Also, there is a distinct "whine" as well.
    If the small rubber "absorbers" are missing from the motors
    fins then you might get a buzzing sound.
  4. parts
    parts Member
    prescott valley az
    oops!
  5. waldo
    waldo Member
    San Jose, Ca. 95125
    What oil do you have in there now? How many miles on the bike what year is it. Maintenance up to date?
  6. bossone60
    bossone60 Member
    16,000 miles maint. up to date 81 xj750 seca just ticks little more than i am used to may be valves
  7. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Ya if you're not used to it, you could take the normal valve ticking to be an issue. But on these bikes, you LIKE to hear the valves :) Reminds me of a chorus of frogs singing :)
  8. wamaxim
    wamaxim Active Member
    Vancouver, USA
    If it's a new noise it just might be an exhaust leak. They often present as a ticking noise. Check where the headers bolt into the exhaust manifold using a 2' length of hose. If you use a smaller diameter hose (1/4 to 3/8") you should be able to snake it in around the collector and along the full length of the exhaust. If this is it it should be very noticeable when you get to the leak.
    Loren
